Questions: B-Swap & Front Big(ger) Brake Conversion. - Honda-Tech
Old 03-19-2017, 10:21 AM   #1
Default Questions: B-Swap & Front Big(ger) Brake Conversion.
Hey everyone
I'm currently in the process of b-swapping my EF. After some google search, I found that I would need DA axles to do the swap. The DA axle will requires me to remove the dust cover on both the spindle(of the EF) and axle for some much needed clearance for the axle.
My question is, if I do a DA front knuckle swap(for the bigger brakes) at the same time for my EF, will I be able to keep the dust cover? Where I live, it gets really dusty along with rain, I'm worry things might get rusted etc.
Any insight is greatly appreciated. Thanks.
Highny is offline   Reply With Quote
Old 03-22-2017, 08:25 AM   #2
PHANTOM MENACE
24TEN's Avatar
Default Re: Questions: B-Swap & Front Big(ger) Brake Conversion.
That's actually a really good question. In for an answer.
2 things:
1.) When doing the rear trailing arm swap from a second gen Integra you gain a few mm of width. It would seem logical that the same might happen with the front knuckles though I don't think anyone has documented that before.
2.) For years swapping second gen Integra knuckles was taboo on the basis that the geometry would be ruined to the point that it could not be corrected even with adjustable arms. Not sure if that was ever debunked.
24TEN is offline   Reply With Quote
Old 03-22-2017, 09:06 AM   #3
Quote:
i didn't know it would be widen. I don't really mind since I'm going with lower offset rims anyways. Good to know.
'Ben(winhpde)' got a good write up regarding this. From the sound of it, the effect won't be as bad as some may say. I'll have to source out some knuckles and give that a go.
Old 03-23-2017, 06:49 AM   #4
im pretty sure doing a da knuckle swap just gives you alot of camber and kills caster but the ef chassis works off of caster also it more unsprung weight so i wouldnt. you can get a custom front brake mount hole conversion its like a plate with threads in it. forgot the company that made it help honda tech.
crookson speed is offline   Reply With Quote
Broke my front windshield... B_Swapped93 Acura Integra 8 08-06-2015 11:39 AM
Will a bad ISB do any harm in the long run? B_Swapped93 Acura Integra 6 05-11-2015 03:57 PM
Del Sol VTEC Dual Core Radiator Info PaleAleS2k Honda Civic / Del Sol (1992 - 2000) 4 12-12-2013 03:37 PM
disc brake convserion hangup hammergunner Honda CRX / EF Civic (1988 - 1991) 3 03-04-2012 09:35 PM
dust cover removal? bradpee Honda CRX / EF Civic (1988 - 1991) 2 04-18-2009 07:40 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
  • Ask a Question
What's your question?
Send
