Popping noise front right
New User
1990 Honda Civic DX, Automatic
I have a popping noise that sounds like its coming from the front passenger side when I am moving. Any ideas?
Thanks,
Josh
Thanks,
Josh
Re: Popping noise front right
could be a few things. when does it occur? while turning, while accelerating and decelerating, both? it could be a bad inner or outer cv joint on your axle. common signs to indicate a axle is most likely bad is you will find ripped/torn cv boots and the grease will be flung around everywhere. it could also be a bad ball joint. check them out and also look at the shape of the bj (hehe) attached to the tie rod end.
GReddy SI
12
07-17-2003 04:07 AM
