piston hit the spark plug???
Old 10-29-2008, 11:57 AM
  #26
SoCalEF'in's Avatar
Default Re: piston hit the spark plug??? (96civic909)
**First make sure you aligned the cams and the crank to TDC Corectly... if you did and its still making a "bubblely" noise then it a posibility....
you could have spun 3 of the 4 rod bearings causing the piston to hit the plugs.
have you checked you oil to see if there are any metal shavings.. had this problem once before the engine started to sound like a WRX .. and RPM climbed very slow. i dont know if this sounds like your problem, but if you have changed the head, and gasket, check that engine is at TDC ,but its still doing the same thing.. try dropping the oil pan and looking at the rods bearings.
Modified by SoCalEF'in at 1:08 PM 10/29/2008
Rasmusm
26
08-21-2013 11:44 AM
honda305
12-01-2010 09:14 PM
bunnyrabbit
07-02-2007 09:29 AM
JDM_lover03
08-15-2005 10:14 AM
HamiltonRex
02-27-2004 03:43 PM
Quick Reply: piston hit the spark plug???
