oil pan torque specs??? - Honda-Tech
Old 08-05-2004, 01:39 PM   #1
hugh_jazz_sponer's Avatar
Default oil pan torque specs???
anyone know the ft./lbs I need to torque the oil pan bolts to on a D16A6? I searched and saw a couple of guesses but nothing definite. I am waiting for my helms to arrive but i would like to take care of this in the next day or two. i think it's between 9-15 lbs or so.
thanks
hugh_jazz_sponer is offline   Reply With Quote
Old 08-05-2004, 01:48 PM   #2
eda6's Avatar
Default Re: oil pan torque specs??? (hugh_jazz_sponer)
9 ft.lbs
eda6 is offline   Reply With Quote
Old 08-05-2004, 01:54 PM   #3
MR5 EF9's Avatar
For a D16A6 apply liquid gasket (hondaBOND or like product) to the 4 points where the pans dips for the crank, apply between the gasket and oil pan
tighten bolts and nuts finger tight at six points starting in the center (number 1) above the drain plug, directly across, then both ends (left and right side)by the dips for the crank.
tighten all bolts and nuts starting from bolt 1 (number 1) clockwise in three steps
Torque 14N.m (1.4 kg-m, or 10 lb-ft)
Excessive tightening can casue distortion or the oil pan gasket and leakage
i use a 1/4 in rachet with a 6 inch extension and a deep 1/4 10 mm 6 point socket
does the trip every time, also i use a small amount of GASKASINCH on the gasket itself and oil pan ensures a seal
MR5 EF9 is offline   Reply With Quote
oil pan gasket is squeezing george34 Honda CRX / EF Civic (1988 - 1991) 5 11-09-2016 10:44 PM
oil pan swap any tips? Civic Racer X 7 Honda Civic / Del Sol (1992 - 2000) 2 05-23-2007 01:42 PM
Oil pan gasket... what am I doing wrong??? firewalkerr Acura Integra 10 02-13-2006 06:56 AM
Torque specs 4 Oil Pan bolts XRatedGSR Acura Integra 2 02-08-2003 10:54 AM
oil pan studs,torque?handtighten? internet ay Tech / Misc 1 07-31-2002 12:46 PM
Tags
2004, 22, 99, acura, civic, gasket, honda, hondatech, inch, lbs, oil, pan, specs, tech, torque, tq
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
