Official EF CRX/Civic water leak thread - Honda-Tech
Old 09-06-2010, 05:44 PM   #1
gringo7718's Avatar
Default Official EF CRX/Civic water leak thread
There are several places where the Civic/CRX EF chassis tend to leak. After 20 years the seam sealer is starting to dry-rot and develop hairline cracks for water to leak in through.
Finding a leak can be very hard to do...
The best way to identify where a leak is coming from is to disassemble the interior panels of the area in question. Then get inside the car and have a friend wet the car with a hose on specific areas. Try to wet each area one at a time so that you can narrow down where the water is leaking in. Because of folds in the sheet metal etc. it may be impossible to see the actual leak. You have to understand that water will trickle down behind panels and become visible in a completely different area of the car. Once you have identified where it is leaking you can use the appropriate method of re-sealing it.
The correct way to repair these types of leaks is by using a wire brush and drill, and grind off all the old seam sealer in the area. Then apply new seam sealer and then paint if needed. Or if you are a broke student like me, you can just silicone over the cracks (I like the high-temp RVT black silicone). It is important to really clean the area and let it dry to get the best seal possible adhesion.
The infamous hatch shock area where water collects
1. Sunroof and drain tubes - The drain tubes can be clogged with debris like sediment and leaves which will prevent the drain pan from draining. The pan fills up and spills over on you as you drive to work in the morning. The tubes can also become disconnected behind the paneling and fill your trunk with water. You should remove the interior panels and disconnect the drain tube from the drain pan. Use compressed air to clean out the lines.
Here is a nice write-up: https://wwwx.cs.unc.edu/~hays/crx/crxsunroof.pdf
Here is a write up on how to remove headliner: http://crxcommunity.com/viewtopic.php?t=1340
Civic hatch sunroof drain tubes
2. Rear
washer nozzle gasket (on the roof)
The symptoms are leaking into the hatch shocks area and down the panels into the trunk. You can create your own seal or use silicone to seal the nozzle down. To remove, use two old “credit cards” and slide them from front and rear to depress the retaining clips.
3. Roof drain channels (under the black trim, each side of the roof)
This usually appears as water collecting in the hatch strut area, and the seam sealer wears out. The entire section of seal can be a problem but the rear corners are especially notorious for leaks. Use silicone to seal the hairline cracks in the seam sealer.
Here is an excellent write up on that: http://www.crxcommunity.com/viewtopic.php?f=10&t=10036&start=125
http://www.honda-tech.com/showthread.php?t=1958029
4. Rear Tail light gaskets
Over time the tail light gaskets dry out and crack allowing the leaks. You can make your own gaskets out of foam from a hobby store or apply silicone sealant around the edges your old one. then reinstall while silicone is still tacky.
Here is what it looks like when the gaskets leak and the water leaves marks on the chassis
Clean the old gasket. Apply silicone to the sealing edges and reinstall tail lights.
homemade gaskets
5.
Rear hatch mounting hinges
Usually the seam sealer is dry and cracked and all it takes is a small hairline crack to allow a leak. You can remove the hatch and strip all the old seam sealer and redo it all or silicone the edges of the hatch hinges.
Here is a write up: http://htarchive.org/showthread.php?t=2222273
(You can do a cleaner job than this guy)
6.
Windshield seal
When the windshield seal goes bad it will usually leak in the front foot well area on the side that has the leak.
7.
Front Cowl Area and Hood Hinges
Seam sealer here can go bad here as well. Water can also leak in through the “fresh air vent” located under the cowl on the driver’s side. You can remove the fresh air vent and clean it and silicone it down.
Driver's Fresh air vent
Passenger Fresh Air Vent Inlet
- I just discovered this one in a strong downpour the other day. It started leaking from behind the glove box and dripping on the carper just in front of my ECU. After I removed the cowl I could see the wet areas and how the water got in. The problem was the plastic clips that are the "screw anchor" for the hood cowl (yellow arrows). They were old and dry rotted and cracked. It is hard to tell from this pic but they are directly above the opening in the chassis that pulls in fresh air. I also sealed the plastic cover panel (green line).
8. Antenna Seal
The water usually trickles down the inside of the pillar and results in a leak on the drivers foot well.
9. Water leaking in through Front Speaker
Usually the plastic water barrier has been torn and allows water in through the speaker grilles. To fix it, remove the old plastic sheet and trace it onto some new plastic liner material and cut it out and attach. I used plastic “drop cloth” material from home depot but almost anything will work.
10. Door Hinges Area - (Not a common problem..........yet)
I actually saw these pictures and thought it is only a matter of time for all of us.
http://www.crxcommunity.com/viewtopi...0036&start=125
My hood hinges
gringo7718 is offline   Reply With Quote
Old 09-06-2010, 09:46 PM   #2
SlobberGoat's Avatar
Default Re: Official EF CRX/Civic water leak thread
Sticky this.
SlobberGoat is offline   Reply With Quote
Old 09-06-2010, 09:53 PM   #3
D16SiHatch's Avatar
good stuff man
D16SiHatch is offline   Reply With Quote
Old 09-06-2010, 11:03 PM   #4
I have a leak you didn't cover. In the trunk when you reach in and remove the cover to the left tail light. I'm getting water on the wall of the side of car. Not near the tail lights farther up a little pasted the sunroof drains. Its not the sunroof drains, already checked that.
michael-crxsi is offline   Reply With Quote
Old 09-08-2010, 06:52 PM   #5
gringo7718's Avatar
In order to find where the leak is, you have to remove some interior panels and have someone wet the car. You can also try to spray soapy water on the outside where you suspect the leak, and blow compressed air from the inside (look for bubbles on the outside).
If I understand correctly the water seems so be leaking in from somewhere "above" the rear tail lights (wiper nozzle, hatch hinges, glass seals, roof drain channels) and leaking down the inside of the rear hatch pillar and draining out near the taillights. It could also be a bad rear window seal or maybe a sunroof drain tube separation. Good luck and let us know what you find.
Here is a write up on the tube separation: http://crx1.com/2009/09/09/sunroof-drain-hoses/
water running down the inside of the rear hatch pillar
Old 09-08-2010, 07:46 PM   #6
mikecp's Avatar
This is great info right here. I have water pooling up in the rear seats footwell. the space behind the passenger seat (?) Would that be the taillights?
mikecp is offline   Reply With Quote
Old 09-08-2010, 09:06 PM   #7
Who the fack changed my title?!
sh!ft's Avatar
i vote to sticky this
1.sh!ft
sh!ft is offline   Reply With Quote
Old 09-15-2010, 12:20 PM   #8
Sticky!
Old 09-15-2010, 04:26 PM   #9
iwannarace's Avatar
Lol I took the 91 hatch i bought a month ago through the car wash today for the first time and it started leaking like crazy all over the passenger seat and on the floor board... nice job with the research this will be useful.
iwannarace is offline   Reply With Quote
Old 09-15-2010, 04:29 PM   #10
sh!ft's Avatar
STICKY THIS PLEASE
Old 09-15-2010, 08:29 PM   #11
xalents23's Avatar
Great info.
xalents23 is offline   Reply With Quote
Old 09-21-2010, 09:17 PM   #12
keep this post alive, love it
JDMhonda90 is offline   Reply With Quote
Old 09-23-2010, 10:55 PM   #13
EFB055
~sp33~'s Avatar
Nice, always lots of posts about this, noone ever really going in to detail.
~sp33~ is offline   Reply With Quote
Old 09-24-2010, 10:38 AM   #14
gringo7718's Avatar
Just discovered this one the other day. A crack this small CAN be the cause of a leak.
Old 09-24-2010, 05:35 PM   #15
rbwdriven's Avatar
I know what i'm doing when I rip my car apart
rbwdriven is offline   Reply With Quote
Old 11-11-2010, 05:20 PM   #16
Tyson's Avatar
nice thread.
heres my cleaning the rear drain tube.
http://honda-tech.com/showthread.php...1#post43992501
Tyson is offline   Reply With Quote
Old 12-19-2010, 08:07 AM   #17
Fo-Do Fanatic's Avatar
Okay well I have a leak that hasn't been covered. Been trying to find it for over a year and to no avail.
I have water that leaks down the c-pillar panels and onto my speaker trays. Everytime I spray water on the car it will NOT leak, but when it rains that's when it leaks. I can't figure it out...I'm starting to get pissed lol. It's been pissing rain for the last two days and I have wet back seats and a puddle in the trunk
HELPPPPPPPPPPPPPPPP
Fo-Do Fanatic is offline   Reply With Quote
Old 12-19-2010, 08:36 AM   #18
And my car has all of these. My fix is drill a hole in the floor board. I had 2 inches+ of water after 2 days of light rain.
96Formula6spd is offline   Reply With Quote
Old 12-19-2010, 09:48 AM   #19
tonythetuner®'s Avatar
Good info this needs to be stickyed. I got a leak it my hatchback when it rains I gett a puddle in my trunk area jus bought the car
tonythetuner® is offline   Reply With Quote
Old 03-15-2011, 05:43 PM   #20
spoon.ek9's Avatar
excellent info! i've got two leaks i need to take care of:
1. driver's side carpet: it seems like it's only on circle within the middle of the floormat.
2. passenger side: water drips down from the right side of the glove box. i'm getting massive amounts of water there (i've jammed a towel in there for now).
i will most definitely give the above leaks a look when better weather arrives
spoon.ek9 is offline   Reply With Quote
Old 12-06-2011, 12:57 AM   #21
I have a 90 crx, but the hatch had been swapped with a hatch from a si crx, could the alignment effect any leaks?
CrxRoy is offline   Reply With Quote
Old 12-06-2011, 08:24 AM   #22
sohc_ef2's Avatar
this helps me out alot i have a couple leaks i got ot fix and thsi narrows it down for me quite a bit... nice post man
sohc_ef2 is offline   Reply With Quote
Old 01-04-2012, 01:59 AM   #23
water pools in my back driverside foot well and i cannot find the leak!!
shunpike is offline   Reply With Quote
Old 01-05-2012, 10:58 AM   #24
great write up!
redef90si is offline   Reply With Quote
Old 01-11-2012, 04:44 PM   #25
i have a water leak in front of my passenger seat!! it happens while i drive...any help
jrsh0526 is offline   Reply With Quote
MD 2000 white Civic turbo coupe. GT35R sleeved Taffetaturbo Vehicles for sale 24 02-23-2016 05:18 PM
Leaking roof rails? Water woes. FlewByU352 Honda Civic / Del Sol (1992 - 2000) 4 09-19-2015 08:48 AM
1993 civic ex sedan passenger water leak HELP!!! DeDonDeRosa Honda Civic / Del Sol (1992 - 2000) 7 10-05-2011 07:01 AM
4th Annual Airwerks by BW Outlaw FWD Street FWD Shootout Oct 1-2 E-Town4229 Drag Racing 1202 10-05-2011 05:56 AM
water leaking from a/c evaporator? help!!! gringo7718 Honda Accord (1990 - 2002) 7 06-24-2002 11:45 AM
Tags
1990, civic, coming, crack, crx, ef, foot, fresh, gasket, hinges, honda, hood, leak, line, official, problem, sealer, water
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
