obd1 codes - Honda-Tech
obd1 codes
Old 04-01-2004, 06:35 PM   #1
HamiltonRex's Avatar
Default obd1 codes
Today my buddy came over and hes wanted to hear what my exhaust sounded like.
Anyways it was very damp out and the motor was cold, it was a bit above freezing, and i reved my cold engine to 6k, when i let off it dropped down bogged then died.
After 2 minutes of sitting it runs fine but im getting a code.
Its a obd1 P28 Ecu, it goes blink......blink......blink..blink. 2 long blinks then 2 short ones.
Anyone know what this means so i can fix whatever it is?
Thanks alot!
-Eric
HamiltonRex is offline   Reply With Quote
Old 04-01-2004, 06:46 PM   #2
civickiller's Avatar
Default Re: obd1 codes (HamiltonRex)
first i would try and reset the ecu and see if you still get that code
variable vavle timing and valve lift electronic control pressure switch( vtec pressure switch)
civickiller is offline   Reply With Quote
Old 04-01-2004, 06:59 PM   #3
Default Re: obd1 codes (civickiller)
yeah ill go try that, i dont see why that would come one... geeze.
-Eric
Old 04-01-2004, 07:13 PM   #4
she fix, reset it .
-Eric
Old 05-03-2011, 05:08 PM   #5
i have a obd1 h22a p13 ecu and i swap the h22a obd1 in my 1992 honda accord ex wagon what wire do i have to conect to hook up the vtek is it the vtek solenoid and the knock senssor duzz eny one know what i need to do
lizard man is offline   Reply With Quote
OBD0 mystery code crazyhorse2011 General Discussion and Debate 15 03-25-2016 07:39 PM
OBD1 code reading question Bluegixxer1k Honda Civic / Del Sol (1992 - 2000) 7 05-24-2011 04:55 PM
Can somebody plz help me with this TCU code? LS_teggy Acura Integra 0 07-11-2010 10:53 AM
Can anyone make sence of CEL codes? One Low Accord Honda Accord (1990 - 2002) 4 05-30-2008 05:35 PM
code 17 after clutch swap Chrisrey86 Honda CRX / EF Civic (1988 - 1991) 1 05-13-2007 11:16 AM
Tags
1992, acura, blink, civic, clear, code, codes, complete, honda, hondas, hondatech, nsx, obd1, p28, reset
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
