flywheel cover installation
Old 10-22-2008, 08:41 PM
hatcht9x's Avatar
Default flywheel cover installation
So Me being as cool as I am.. put the flywheel/clutch on first (forgot to put the cover on )
when I searched.. People said you can do it if you take off the two tranny brackets that bolt to the block.. and it just slips in??
any help would be great!
TIA
Old 10-23-2008, 03:39 AM
rbwdriven's Avatar
you have to loosen th two lower aluminum brackets that connect to the block to the tranny. once you do that it will slide in.
Only issue you might have is the header might be int he way of the bolts.
that is how I did mine.
Old 10-23-2008, 03:50 PM
hatcht9x's Avatar
Default Re: (rbwdriven)
awesome! thanks for the info man!
(you are right about the bolts clearing the header)..
thanks again!
Modified by hatcht9x at 8:04 PM 10/23/2008
Old 10-23-2008, 07:03 PM
hatcht9x's Avatar
Default Re: (hatcht9x)
As a de-briefing:
I got it!.. I was able to slip it in by only removing the rear block-to-tranny bracket..
thanks for the help rbwdriven
Old 10-24-2008, 12:16 AM
PHANTOM MENACE
24TEN's Avatar
I like when people post up their results to the issues they overcome. There are countless threads where the OP doesn't post the solution or technique they used to address their issue. I know this thread was rather simple but someone in the future will come across this information in their time of need.
Old 10-24-2008, 07:48 AM
rustbucketrex's Avatar
Default Re: (24TEN)
x2 /\
Old 10-24-2008, 06:49 PM
hatcht9x's Avatar
Default Re: (rustbucketrex)
for sure! I hate that too
verbol assassin
10-07-2005 07:09 PM
Hatch It
06-07-2005 02:08 PM
lildrgn2.0
06-22-2004 06:56 AM
Unjockable
08-03-2003 02:22 PM
Quick Reply: flywheel cover installation
