No Brake Lights - Honda-Tech
No Brake Lights
Old 06-18-2010, 10:03 PM   #1
Default No Brake Lights
Hey guys my brake lights are not working on my crx. I have checked the switch and its working. Replaced with a working one and no change. However the taillights work with the lights on no problem. However when I hit the brakes the door ajar light comes on. The front body harness is new and the back is the original. It does not look cut. I have the rest I just need to install it. I have a feeling they were not working before I swapped the front body harness. Any ideas or things to check? Trying to get this fixed before I get pulled or worse an accident.
96Formula6spd is offline   Reply With Quote
Old 06-18-2010, 10:07 PM   #2
EFficial's Avatar
Default Re: No Brake Lights
check the plug above the brake pedal and pull your rear lights for and loose/open wires
EFficial is offline   Reply With Quote
Old 06-18-2010, 10:08 PM   #3
plug is in. Lights were checked and everything looks good.
Old 06-18-2010, 10:33 PM   #4
Did you check the fuse?
littlewagon is offline   Reply With Quote
Old 06-19-2010, 11:57 AM   #5
yep fuse is good unless its separate from the taillight one/cluster one
Old 06-19-2010, 12:04 PM   #6
if the fuse is good and everything is plugged in. it could either be the switch itself or the wireing.
black0hatch is offline   Reply With Quote
Old 06-19-2010, 12:05 PM   #7
yeah its down to wiring. Switch got replaced and no change. They worked when I bought then a week later they did not. Going to rewire the car from the dash to the back and forget about it.
Old 10-16-2010, 04:57 PM   #8
Rease3's Avatar
update on fix?
Rease3 is offline   Reply With Quote
Old 10-16-2010, 09:02 PM   #9
Quote:
Originally Posted by Rease3 View Post
update on fix?
Ended up running a new power wire to the switch. Works great now. 10 min job over a couple of hours for the whole harness change.
Old 10-17-2010, 10:08 AM   #10
tunerEF9's Avatar
this did the same thing in my 91 hatch i just ran a new wire also, curious though why this is happening kinda strang maybe its just an ef thing lol...
tunerEF9 is offline   Reply With Quote
Old 03-19-2012, 10:21 AM   #11
BiG ChOr!Zo's Avatar
Quote:
do you got a diy on how you did this. my brake light fuse keeps blowing out and only the regular lights stay on in the rear. im figuring there is a short somewhere but rather than tear out the engire wiring this seems like a ok fix for now.
BiG ChOr!Zo is offline   Reply With Quote
Old 04-12-2012, 09:42 PM   #12
91STDFLOW's Avatar
Same here, my hatch just had all three brake lights stop working, fuse is fine, brake grommet is new, bulbs look good, only thing I can think is ground in wire somewhere.
White and green wire is power correct? Any hint on size?
91STDFLOW is offline   Reply With Quote
95 integra gsr electrical problem need help asap Borintegra Tech / Misc 7 06-15-2016 10:01 AM
2000 Accord Coupe Brake Lights accordfixit Honda Accord (1990 - 2002) 21 06-18-2014 10:12 AM
Taillight has me boggled. dogbiscuit Honda Element & CR-V 1 10-15-2013 02:34 PM
Brake lights dont work! egdro Honda Civic / Del Sol (1992 - 2000) 15 07-28-2013 01:06 PM
help, brake lights malfunctioning!!! Mr. Vapor Honda CRX / EF Civic (1988 - 1991) 5 12-07-2002 01:50 AM
Tags
08, 1990, 90, brake, civic, crrx, crx, door, honda, light, lights, open, si, touch, working
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
