B16 cable trans leaking from right axle seal
Old 02-08-2011, 09:05 PM
Dark Star's Avatar
Default B16 cable trans leaking from right axle seal
Where can I get that axle seal ? I was thinking off of a da ls cable trans but I really have no clue . Can anyone help
Thanks in advance
Old 02-08-2011, 09:11 PM
projectTeG's Avatar
Default Re: B16 cable trans leaking from right axle seal
you can use any passenger side b series axle seal i believe.
Old 02-08-2011, 10:53 PM
v8killaz's Avatar
make sure tranny is not overfilled. mine was leaking for days
bitch has 5 quarts of tranny fluid lol
Old 02-08-2011, 11:23 PM
hatchet_honda's Avatar
Thanks in advance
you bought this car already swapped didnt you? lol...ummm well you can go to autozone or wherever and ask them for an output shaft seal for the trans you have. since its a cable trans get a seal for sayyyyy a 91 integra ls. done
Old 02-09-2011, 12:01 AM
Dark Star's Avatar
Thanks for all the help guys
Old 02-12-2011, 06:55 PM
powerpro_69's Avatar
i have a seal kit
SK-S1/Y1 Acura Integra Y1 YS1 S1 Cable Transmission Seal KIt
2 axles seals, input seal, shift rod seal
comes with 4 seals all oem honda
$45 shipped
Old 02-12-2011, 07:39 PM
theft24's Avatar
lol is that even possible?
Old 02-12-2011, 09:09 PM
lazy14's Avatar
i work at a lube shop for the last 5 yrs and have never seen a manual trans that over full holy **** it still worked????
Old 02-12-2011, 10:46 PM
v8killaz's Avatar
yes this thing was filled over 5 quarts. i was draining it and the oil pan got full. then i drained them into smaller oil quart bottles and i filled over 4
thats trans was not completely drained either
Old 04-12-2012, 04:00 PM
jphil101's Avatar
Do u still have seal kit. I replaced my axles with hasport axles and had to replace half shaft and new half shaft is 8th inch in diameter too small so it leaks oil from tranny where half shaft goes
Old 04-12-2012, 04:10 PM
KINGVEM^^ED6's Avatar
Go to vatozone there 8 bux
jonnyt1130
Transmission & Drivetrain
15
08-30-2009 05:42 AM
boosted91REX-SI
03-29-2009 10:55 PM
ComeOnKip
05-19-2006 11:26 AM
Quick Reply: B16 cable trans leaking from right axle seal
