Nippon/ NPR piston rings for D16a6 - Honda-Tech
Old 04-17-2009, 10:17 AM   #1
4DRmafia's Avatar
Default Nippon/ NPR piston rings for D16a6
I was wondering how precise are they? Close to oem? I test fit them on a scrap D16y7 piston to see how well it fits and it seem to be hard to get in the grooves. I don't know if D16y7 piston are different from D16a6.
4DRmafia is offline   Reply With Quote
Old 04-17-2009, 01:44 PM   #2
xaine's Avatar
Default Re: Nippon/ NPR piston rings for D16a6
i dont know the quality of the rings. i did instal those on my car and it seems to be fine.
The d16y7 has the same bore so...
if i was to guess ,
they can be hard to get on the piston if you didnt clean the grooves out
xaine is offline   Reply With Quote
Old 04-17-2009, 02:46 PM   #3
4DRmafia's Avatar
It's like the rings don't want to go in and I have to press them in hard.
Old 04-17-2009, 07:32 PM   #4
redflaredcrx90's Avatar
new rings are a lil hard to put on some times the do make tool to help out
redflaredcrx90 is offline   Reply With Quote
Old 04-17-2009, 09:49 PM   #5
xaine's Avatar
just be careful doing that, you can break a ring when you go to compress them for instalation
I actually did break one when i did mine.
have you double check your pat number?
d16y7 with pm7 pistons and webber40 manuel3655 All Motor / Naturally Aspirated 0 05-20-2007 06:19 PM
d16z6 d17 crank 96accordlxf22b2 Honda Civic / Del Sol (1992 - 2000) 10 02-01-2006 09:26 PM
d15b7 pistons in a d16y8 wrXtian Honda Civic / Del Sol (1992 - 2000) 10 12-22-2003 10:16 PM
d16a1 pistons in a y7 wpgcivic Honda CRX / EF Civic (1988 - 1991) 2 12-18-2003 08:04 PM
NEW 4340 Rods and Forged Pistons 4 sale formervendor For Sale 2 10-17-2003 06:51 PM
Tags
1991, 88, bore, crx, d16a6, good, home, honda, hondas, nippon, npr, page, piston, pistons, rings, si
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
