Need help!! D16z6 swap in ef sedan lx
I need help swapping a z6 in my 1991 ef sedan lx, I have everything just need to know how to wire it and get it running, and what engine mount do I use , because the driver side mounts will not align. Help!!! I have both harness (z6 harness and b2 harness)
Re: Need help!! D16z6 swap in ef sedan lx
I know for a fact that u would need the z6 ecu, im planning a mini me wich is your z6 head and the b2 block, i would need it for mine so i guess that would probly be best to use the z6 harness although its not entirely necessary depending on what your building it for and the mount is probly already aftermarket meaning u wont have to go to the machine shop and get one fabbed. Hope i at least helped a little.
Keyboard Humorist
I'm not going to spoon feed the answers. This swap is nothing new. Check out h FAQ sticky at the top of this page and search google.
Come back if you have detailed questions after that or if you get confused.
PHANTOM MENACE
First of all, the block will fit together with the tranny but you will need to use the A6 driver's side mount and bracket to fit it in.
The first picture is with the Z6 mount and bracket in place and the second picture is with the A6 mount and bracket in place. Note that the mount is farther forward when using the A6 mount and bracket.
H-T Premium Sponsor
you can use a EFD2LH with a factory 92-95 2 bolt block bracket and keep the 92-95 timing covers and everything fits properly
No Big Whoop
I love your mounts Hasport. This is one of those few instances where 2 minutes with a dremel and one or two washers get the job done just fine.
Keyboard Humorist
What do you need washers for? I ran this setup long ago (before HASport mount was invented) and no washers were used.
Personally, I would have preferred the HASport mount. Looking at the hole I had to cut into the timing belt cover always looked bad.
Yomage_EG
09-24-2013 11:26 AM
