need help..cluster problem
when im going down the road or moving at all the tempature needle will rise almost to the top and when u turn the turn signal on..the tempature needle will jump up and down with the turn signal and when u click on the bright lights the tempature needle will also rise...but when u are sittin still the temp. needle is at normal tempature and doesnt move and will not jump with the turn signal...it makes no sense to me so if anyone knows anything..please let me know
Re: need help..cluster problem (SinSeven)
That does sound like a bad ground. My original cluster did that prior to my new cluster being installed. I chased the wiring, and found that one of the wires had beed rubbing on a metal bracket for some time and had chewed away the insulation. I patched the insulation and made a nice little rubber grommet to fit the hole in the bracket and I have not had any problems since.
wes7side5o
03-22-2007 05:07 PM
ImportsCRX
10-23-2004 04:52 PM
