Help with CRX d15b swap
Old 07-09-2005, 02:40 PM
Paperweight's Avatar
Default Help with CRX d15b swap
I got a d15b a long time ago, I put in my 91 crx si and it has been sitting for the last 6 months, i was interning in FL. Now I got home and I wired most of it up using a boom slang conversion harness.
i got the VTEC wired and I am using a bosch 02 sensor and it has 2 whites a black and a grey wire. my conversion harness has orange white grey black. which wires go to which? i lost my sheet which said what wires go where. shouldn't the car start with out the wiring done on the o2?
now i got the distributor out of a 92 civic Si and I wired up the match colors to each except the distributor had a white wire that I matched with the orange on the wiring harness... what should the firing order be?
where should the ground wires be? I have one from the valve cover to the body, next to the radiator...shouldn't there be more? I filled all the fluids. when I turn the key it clicks... what could the problem be?
any help would be greatly appreciated, and sorry for all the Newb questions
Old 07-09-2005, 06:21 PM
jspecPR26's Avatar
Default Re: Help with CRX d15b swap (Paperweight)
i think the distributor it happen to me i got the same set up, same car...good luck
Steveramirez21
08-24-2013 05:28 PM
dusterbd13
09-19-2009 09:32 PM
95_red_dc
04-19-2006 10:01 AM
Dainbramage
06-28-2004 03:42 PM
Quick Reply: Help with CRX d15b swap
