My car won't start when it's HOT outside!!?? - Honda-Tech
Old 05-28-2006, 12:46 PM   #1
TealCivic93's Avatar
Default My car won't start when it's HOT outside!!??
I left my house this morning when it was cool outside. Didn't have a problem. This afternoon though when the temperature was at it's peak the car was turning but not starting. Last summer it happened sometimes but I would wait a few minutes and it would start after. Would I need a tune up? Thanks
TealCivic93 is offline   Reply With Quote
Old 05-28-2006, 02:00 PM   #2
Deo
Deo's Avatar
Default Re: My car won't start when it's HOT outside!!?? (TealCivic93)
Most likely the Main Relay, easy fix. Search it for a guide.
Deo is offline   Reply With Quote
Old 05-28-2006, 02:05 PM   #3
I tell doctors what to do
ILcrxsi1's Avatar
Default Re: My car won't start when it's HOT outside!!?? (Deo)
Quote:
ILcrxsi1 is offline   Reply With Quote
Old 05-28-2006, 02:18 PM   #4
thanks. I will search for it. I was told the same thing on a local forum.
Thanks again.
JF
Old 05-28-2006, 10:40 PM   #5
nostreble's Avatar
Default Re: (TealCivic93)
if its the main relay, just let some air inside the car too cool down.
nostreble is offline   Reply With Quote
Old 05-29-2006, 06:49 AM   #6
crx_88_si's Avatar
Default Re: (nostreble)
Quote:
only works *sometimes*. Mine had the same problem.
I found if i sat there cycling the key to on / off / on / off eventually it would work, but then i had to change my ign switch. so, replace the relay, lol.
crx_88_si is offline   Reply With Quote
Old 05-29-2006, 07:28 AM   #7
'90crxSI's Avatar
It is definetly the main relay. Detailed problems and a fix can be found here: http://www.tegger.com/hondafaq/faq.html#startrun
Soldering is very easy on this! I've done mine, and no longer have problems! Give it a shot!!!
'90crxSI is offline   Reply With Quote
car wont start when its hot outside djcvaughn Honda Accord (1990 - 2002) 10 09-10-2012 02:14 PM
95 accord wnt start when hot outside please help boosted96midorihatch Honda Accord (1990 - 2002) 2 09-25-2010 04:11 PM
1991 integra DA weather issues? Auby Acura Integra 6 10-01-2008 01:13 PM
Car WON'T start if over 80 degrees outside, hmm? MyThreeDailyDrivers Honda Accord (1990 - 2002) 2 06-04-2004 09:25 AM
Attn: Alarm experts, Remote Engine starter problem when cold outside. mickey513 Audio / Security / Video 6 10-29-2002 09:20 AM
Tags
1990, accord, car, civic, cool, ef, honda, hot, key, main, my, outside, relay, start, starting, trouble, turn, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
