Master Cylinder Upgrade - Honda-Tech
Old 05-27-2008, 07:42 PM   #1
persianp's Avatar
Default Master Cylinder Upgrade
It's time for me to start modding my rex after driving it 220K on all stock. I am starting with the brakes. I am not going for bigger brakes, but am first installing stainless steel brake lines. At the same time I want to upgrade my master cylinder.
I've got a 91 crx si, so to go bigger I've been reading that I can use a master cylinder from an 89 prelude, or one from a 90-93 integra non abs.
What's the differences? I assume I'll need to buy the booster with the integra, and can keep using the same one in the crx for the lude? Is that right?
Thanks helping me start my modding journey!
persianp is offline   Reply With Quote
Old 05-27-2008, 07:48 PM   #2
LowFlyin''s Avatar
If you aren't changing the brakes, why mess with the master cylinder? Are you planning on upgrading the brakes in the future? The CRX Si already has a 7/8" bore MC. The only larger ones are 15/16" from the Prelude and the 1" (and larger booster) from a GSR.
I got the booster and MC from a '95 GSR, and I had to modify one of the brake lines. Just had to move it from one side to the other.
If you don't plan on upgrading to EX or DA knuckles, I'd suggest you just stick with the stock size. The SS brake lines will give you a noticeable improvement.
LowFlyin' is offline   Reply With Quote
Old 05-27-2008, 07:57 PM   #3
persianp's Avatar
Default Re: (LowFlyin')
I read on a blog, http://madnessmanual.com/2008/...-crx/, that it is an option. But I see what you mean, why upgrade when I'm not changing the brake size, I guess I was getting a little upgrade happy.
Old 05-29-2008, 09:17 AM   #4
drummingpariah's Avatar
Default Re: (persianp)
There's actually a big article on brake upgrades coming up on that page (stay tuned, it's at the editors), but there isn't much reason to upgrade the master cylinder, even with larger calipers. As long as you're only pushing one piston per corner, the 7/8 MC will work just fine. A larger MC will just get you to brake lock-up with less pedal travel, which isn't necessarily a good thing. Improve your response with stainless lines, which don't balloon like rubber lines do. You'll definitely feel the difference.
Thanks for visiting my site, by the way!
drummingpariah is offline   Reply With Quote
Old 06-04-2008, 03:39 PM   #5
Default Re: (drummingpariah)
For anybody who's interested, I did write up an article on front brake upgrades here:
http://madnessmanual.com/2008/...-swap/
EG Suspension and Brakes Upgrade List Kannan08 Honda Civic / Del Sol (1992 - 2000) 1 01-14-2012 07:08 AM
brake master cylinder upgrade 88todab16crx Honda CRX / EF Civic (1988 - 1991) 2 10-26-2008 10:36 AM
Advice needed on bigger brake booster or master cylinder for h22 turbo CRX djnikko Tech / Misc 3 07-09-2006 04:20 AM
crx with b16 brake problem luciffer Honda CRX / EF Civic (1988 - 1991) 7 08-25-2005 02:15 PM
bigger master cylinder rasta420 Honda CRX / EF Civic (1988 - 1991) 4 12-03-2002 01:37 PM
Tags
78, 89, acura, civic, crx, cylinder, ef, honda, hondatech, integra, master, mastercylinder, upgrade, upgradeing, upgrades
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
