first start up running rough
Old 06-02-2008, 02:54 PM
Shikaido2004's Avatar
Default first start up running rough
I have just fired up my b16 for the first time its running a little on the rough side Im not sure why it possibly could be anything....has anyone faced this type of problem and what did you do to fix it? Im using the obd0 sir 88-91 b16a.....
Old 06-02-2008, 03:15 PM
Banned
stevew84's Avatar
make sure all the engine/tranny mounts are tight.
Old 06-02-2008, 03:18 PM
savage91turtle's Avatar
Default Re: first start up running rough (Shikaido2004)
i have the exact same problem i need help as well with that problem
Old 06-02-2008, 03:32 PM
$cat /dev/urandom
sanimalp's Avatar
Default Re: first start up running rough (savage91turtle)
are you throwing any codes?
Old 06-02-2008, 04:37 PM
fireant's Avatar
Default Re: first start up running rough (sanimalp)
I'd start by double checking whether the timing belt is exactly right on the correct tooth, and whether it is properly tensioned.
Old 06-04-2008, 04:20 AM
On timing do the up arrows face vertically up or toward each other, Im not sure how to check timing? I have adjusted the Throttle position sensor and its running alot better, only problem is its idling about 1300rpm should i adjust it a little more or what could be cuasing the higher idle? I did idle at 1900rpm but it went down after the car ran for 5min to 1300rpm...
Old 06-04-2008, 08:23 AM
(760)doogie's Avatar
the up on the cam gears should point up at top ded center, but you look at the little lines at like 9 o'clock on the cam gears, you should line up the cam gears using those, use a ruler os some sort of straight edge , the little lines should line up with the botls too. i could be wrong though but im pretty sure im right
Old 06-04-2008, 02:28 PM
EFSiR's Avatar
are your ignition wires connected properly with the corresponding # plugs???
Masaru
03-28-2013 07:59 PM
crxcess
06-13-2007 09:39 AM
downest
05-23-2006 10:05 PM
Tad
11-06-2003 09:11 PM
PatrickGSR94
04-11-2003 04:21 PM
Quick Reply: first start up running rough
