Manual window crank removal - Honda-Tech
Old 12-16-2005, 12:50 AM   #1
1989CivicSi's Avatar
Default Manual window crank removal
How do you remove the window crank from the manual window doorsills? Was about to take a flathead screwdriver to it, but thought twice ...
1989CivicSi is offline   Reply With Quote
Old 12-16-2005, 01:41 AM   #2
Donkey85's Avatar
Default Re: Manual window crank removal (1989CivicSi)
there is a little metal clip that hides behind the window crank that pins it to the regulator. what u do is get a little pick and pull it right out and off comes the handle
Donkey85 is offline   Reply With Quote
Old 12-16-2005, 01:54 AM   #3
ef92b's Avatar
yep, that will do the trick.
just look under the crank, there's a small rectangular shaped opening just enough to insert the flat tip of the screw driver. slowly pry that U-shaped clip that locks the crank/handle from the shaft.
see the pic. sorry for my poor illustration
ef92b is offline   Reply With Quote
Old 12-16-2005, 09:02 AM   #4
88DXCRX's Avatar
Location: I told you to wait in the truck in Texas, United States
Default Re: Manual window crank removal (ef92b)
click on picture to view:
88DXCRX is offline   Reply With Quote
Old 12-16-2005, 09:08 AM   #5
EL Vap133's Avatar
Once you do it, you'll think it's soooo easy from then on.
EL Vap133 is offline   Reply With Quote
Old 12-16-2005, 09:31 AM   #6
quis23's Avatar
Default Re: Manual window crank removal (EL Vap133)
use a peice of string to pop it rigth out
quis23 is offline   Reply With Quote
Old 12-16-2005, 09:38 AM   #7
crxtreme89h's Avatar
Default Re: Manual window crank removal (quis23)
Use one of these and keep it real
crxtreme89h is offline   Reply With Quote
Old 12-16-2005, 01:28 PM   #8
Default Re: Manual window crank removal (crxtreme89h)
Thanks for all the replies . I was originally gonna just pull the crank off haha, good thing I didn't .
Old 12-16-2005, 02:14 PM   #9
88DXCRX's Avatar
You can also remove the clip with a grease rag..
Drag it through and catch one end of the clip..
To re-install,position the clip as shown in the second picture,
Hold the handle in the postion you want it and give it a slight smack
and it will pop right on..
Old 12-16-2005, 11:03 PM   #10
progress's Avatar
Default Re: Manual window crank removal (88DXCRX)
[QUOTE=88DXCRX]You can also remove the clip with a grease rag..
Drag it through and catch one end of the clip QUOTE]
I was just about to suggest this! Works like a charm.
progress is offline   Reply With Quote
Old 04-06-2013, 10:11 AM   #11
Icon2 Re: Manual window crank removal
I was rolling up my window on driver side when it just got harder to turn and it just shattered
now I need to replace it but where do I start to remove the side panel
Margaret Ruybal is offline   Reply With Quote
Manual window handle problem thedon360 Honda Civic / Del Sol (1992 - 2000) 6 04-10-2013 11:33 AM
door panel removal codrulz Honda Civic / Del Sol (1992 - 2000) 5 05-29-2010 07:37 AM
removing window crank/door panel pompom Honda Civic / Del Sol (1992 - 2000) 4 02-28-2006 05:41 PM
Power window options in DX Cuong-nutz Honda Civic / Del Sol (1992 - 2000) 6 11-20-2004 11:14 PM
Question about removing door panel TarheelFan Honda Civic / Del Sol (1992 - 2000) 3 04-24-2004 01:34 PM
Tags
1989, 1990, 2001, 2005, accord, civic, crank, cranks, crx, ef, honda, manual, removal, remove, window
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
