m.a.p sensor
m.a.p sensor
how do you tell / what are the symptoms of a bad m.a.p sensor . and is there a test like resistance test or anything to test the map sensor
i ask because i have a suspect map sensor
thanks!
thanks!
Re: m.a.p sensor
When I unplug mine, my car just straight up dies. Whether it be from the vaccume source or from the clip on the harness.
What EXACTLY is your car doing?
Re: m.a.p sensor
i have an extra map sensor off a perfectly fine car that i had rear ended. off a 90 crx si, lmk if u want it, 30 dollars + shipping. full map sensor on the firewall.
Re: m.a.p sensor
Usually the car will throw a code if the map sensor is bad. Also bad map sensors I have seen when they go bad will not let you rev over 3k rpm.
I have attached the Factory Service manual for checking out the MAP sensor. Gives the ECU pinout and the voltages you should be seeing.
Hope this helps.
Hope this helps.
Re: m.a.p sensor
thank you guys a ton
the reason i ask is my car bogs/sputters/missfires once it warms up . when it starts doing it i have to mash the gas or let up and it will keep doing it sometimes i turn off my car while driving and back on and it ill got away but sometimes not so thats y i think it a sensor and the only 2 i can think of that would cause this is map or tps
Re: m.a.p sensor
Hope this helps.
Hope this helps.
Re: m.a.p sensor
Re: m.a.p sensor
Hope this helps.
Hope this helps.
lol wow.... i thought i was going crazy , on why my engine wouldnt rev over 3k with a damn brand new s300 -_-
thanks!!
Re: m.a.p sensor
Hello i hav a 2004 accord ex dohc v6. my car starts like ****. dies when ac turns on. i have to floor it to start it. it idles low. n throws a 6 cylinder misfire from time to time. it just idle terrible. i replace intake gaskets and fuel pressure regulator. my nxt guess was idle control sensor. i looked it up n seen imagne on ebay but it doesnt look like mine. (if im looking at right one) can someone post a picture or sumthing where it is or any ideas to help me w my problem : ?
