THE LUNCHBOX!
#26
Re: THE LUNCHBOX!
Yeah I know man, I do have a CRX rear sway bar, only problem is I can't install with the eyelit styled LCA's, well I believe it can only be installed with fork LCA's. Correct me if wrong!
#28
Re: THE LUNCHBOX!
So i've read the eyelit LCA's cannot run the CRX, or any rear seay bar
#30
Re: THE LUNCHBOX!
It is a 88, it did come with fork LCA's but when I bought coilovers I never knew there was a difference (noob days) and then realised I needed to change the LCA's, so I went back and got the guys eyelit LCA's as he was wrecking his EF anyways. So I now need to buy new coilovers with fork bottoms are the rear, and then I can chuck in my old fork styled LCA's
#33
Re: THE LUNCHBOX!
UPDATE TIME WOO!
still a bit behind updating but im getting there because its now party time with new parts coming in! we decided to fix up my axle back exhaust with a nice 2" stainless steel muffler delete. heres some pictures from doing it!
Also bought a DC2R OEM short shifter and installed. Had to grind the base down from 40mm to 30mm which is the same as the ED shifter
#34
Re: THE LUNCHBOX!
If you get a mig welder with a gas tank, your welds will be 100 times better. Not sure what your options are down under, but for under $500(USD) you should be able to get something that welds better.
#35
Re: THE LUNCHBOX!
I've welded many times before with a gas welder, I mastered it with doing completely smooth welds. I've now also learnt the nick to doing so with a gasless mig, more rewarding getting the same without the help from gas. But yes gas makes it easy peasy, could do it behind your back lol
#37
Re: THE LUNCHBOX!
Yeah mate wish we had a TIG, too busy spending money on mods lol. In the picture it's my mate not me, he just doesn't wear a mask when tacking, but wears one when properly welding
#38
Re: THE LUNCHBOX!
I wear my mask all the time haha. I wear it when I grind! I see a lot of people tack without anything over their face and I just can't do it myself.
Doesn't mig welding negate the 'stainless' properties of stainless steel when you weld it? Or is that only when you weld stainless to mild steel?
#39
Re: THE LUNCHBOX!
EDIT: I do like the car.
#42
Re: THE LUNCHBOX!
So today I installed my DA9 BMC + BB to suit my DA9 front brake setup (rear is awaiting new bushing to be fitted) so I left the 40/40 prop valve out. All this talk about having troubles fitting it is.. well its rubbish because we got it out and the DA9 one in in no time! Heres a pic with the DA9 BMC + BB in! We had to bend both the hard lines from Prop valve to the BMC here and there to fit, just did it by hand, easy!
#44
Re: THE LUNCHBOX!
Well I got the master cylinder off as shoen in pic above, then remove the loom clips holding it down to chassis and then we just pulled the booster out legit. Just fell out into our hands, honestly
#46
Haha yeah fair enough. It was rather easy for us, we simply pulled/snapped the clips holding any loom in and un bolted the black bracket, and the fuse box. I pulled out the BB and my mate just pulled the loom forward and down and out she came!
#48
Re: THE LUNCHBOX!
HEY ALL!!
Havn't been updating my build thread as much as I wanted, been flat out/a little lazy, I do apologize. Anyways a bit has actually happened, new seats, rear disc swap, bushings and soon to have track tyres, especially with my next (2nd) track day coming up in under 2 weeks!! So I'll give you a quick run down with whats happened with pics
So I managed to pick up some Sparco Ultra fixed back bucket seats for pretty cheap, fitted them up but I didn't like the feel of them, because I'm a skinny person it hurt my back, had a weird lumbar. So I sold these for a lot more than I paid. Kinda didn't want to sell due to these being slightly rare/discontinued, but I needed to, heres how they looked fitted:
Next I used the money I got from selling them that night to go straight to someone else's and pic up some shmick red Recaro SR3 from the Integra DC2R. They were kinda dirty but thats fine by me, mint conditon on the bucket and sooooo comfy!
Few weeks later my bushing kit had all arrived, finally! Its been hell since March with destroyed bushings all round, squeaking like hell, car swaying along the highway at 80km + ... That also meant I could finally install my Intega DA9 rear disc conversion because the RTA bushing was here. So I dismantled my car and dropped all the parts off to my mechanic whom pressed the bushings in, and then picked them up 2 days later and installed the rest. The rear conversion wasn't that hard at all, the whole thing about dropping the fuel tank for hand brake line isn't true, I didn't touch the tank one bit.
I didn't really take any photos of the new bushings in, was too excited to install them all, but I ran into a problem trying to hook the new handbrake cables up to the pivot point inside. The right was too short and was hard to reach, so I left the handbrake unbolted under the car and managed to fit it, but then just cable tied the line so it wouldn't move around:
With this all done I could then finally get a wheel alignment for track, 0 toe all round, -2.5 camber front -1.5 camber rear:
Track day in under 2 weeks, I need some gauges so I know how my oil temp + pressure and water temp is going whilst I hunting down the best time I can achieve! Bought some Defi gauges, have not yet fully wired them up, only so they power and turn on. Sandwhich plate arrived today as well. Once in I'll try and get a video for you all of the start up sequence, they are pretty cool! Keen to have them working
