LS Turbo B18B1 CRX Si Build Up Suggestions - Honda-Tech
Old 11-16-2004, 09:05 PM   #1
Default LS Turbo B18B1 CRX Si Build Up Suggestions
this is my set up, just got the car a couple of weeks ago:
CRX Si 1988
B18B1 Motor out of a 96 LS with about 90,000 miles
90-93 Tranny, Dizzy, Throttle Body, ECU
Stock Cat 2.25 cat back exhaust
now the turbo kit i have is the Apexi Ball Bearing turbo kit with the IHI ball bearing turbo. i have a front mount intercooler, bov, greddy turbo timer.
list of the stuff i am buying before i put the turbo kit on
- new clutch,prolly exedy stage 1 or 2
- fidanza 7.5 lb flywheel
- Apexi SAFC 2
- low compression headgasket
- blockguard
- 3 in exhaust
- darkstarsracing crossmember/traction bar
- drag radials on 14 in steelies
now what else can i do or get to safely run 10 psi without worrying at all. i really dont want to buy pistons because all i found were 9.0:1 pistons but the stock compression is 9.2:1 so i really dont wanna do that.
would converting to obd1 and runnin an obd1 teg ecu make any big difference before and after turbod?
The DX Rex is offline   Reply With Quote
Old 11-16-2004, 09:22 PM   #2
mrspeaker's Avatar
Default Re: LS Turbo B18B1 CRX Si Build Up Suggestions (nyhustla2k)
you said you have 90-93 dizzy.ecu..etc..
Are you sure you dont have obd1 already because the 90-91 teg is obd0 but the 92-93 is obd1 ..
And I would only trust the safc for low boost because the thing takes away fuel and you dont want that to happen when you have a turbo pushing more air.
Look into uberdata 0bd1----turboedit for obd0....Its free..all you have to buy is the chip burner...Its similar to hondata without the price
..And when you get the turbo set-up on..the first thing you should do is have it towed to a reputable tuner..tuning is costly but its worth it..
mrspeaker is offline   Reply With Quote
Old 11-16-2004, 09:25 PM   #3
i also have an FMU as well
well if i converted to obd1 id obvisouly change the dizzy and ecu
Old 11-16-2004, 09:26 PM   #4
yea i also have someone that is excellent in tuning so having it tuned properly is not an issue
I have 4 Apex Turbo kits for sell. $1300 92-95 EGs. bluesaint For Sale 17 03-27-2016 04:19 AM
TN FS: 1991 Honda CRX Si Turbo Justin91CRXSi Vehicles for sale 3 02-06-2015 07:21 AM
My Turbo List , give me ur advices winner-civic Forced Induction 1 02-12-2014 04:28 PM
FS::: B-series Parts HEADS OR TAILS Southern California (Sales) 76 09-16-2011 11:50 PM
FS....89 CRX HF...... in ATL Georgia Greenb16 For Sale 10 02-13-2007 06:40 PM
Tags
1989, b18b1, big, build, civic, crx, dizzy, ef, engine, honda, ls, lx, setup, si, turbo
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
