lower ball joint!!
lower ball joint!!
im replacing the clutch on my 89 crx dx and im stuck on how to get the knuckle out from the lower control arm. i have a ball joint seperator and it wont get the ball joint to budge. i need help!!!
Re: lower ball joint!! (be8teensee1)
maybe 3lb hammer lol , it seems to work
https://honda-tech.com/zerothread/1912773
small sledge hammer to break it loose and use the separator and hit it like a man! haha
also soak it in wd-40 or pb blaster just keep hitting at it it will come out
You don't have to disconnect the ball joint to get the knuckle free, just remove all the other points on the LCA and it'll swing out of your way, ball joint intact.
chibiko
06-06-2007 08:45 PM
