engine swap for CRX 90
Old 10-29-2003, 10:10 AM
knighthawkacc's Avatar
Default engine swap for CRX 90
I just bought a 1990 CRX SI, I'd like to keep my tranny. What would be the best engine to put in there that workes good with turbo and nitrous
Old 10-29-2003, 10:24 AM
APEX CRX's Avatar
Default Re: engine swap for CRX 90 (knighthawkacc)
FIRST, do a search. then figure how much hp you want, last figure how much money you want to spend. the last one will tell you which motor to go with
Old 10-29-2003, 10:27 AM
-16V-'s Avatar
Well you can try a mini me swap real cheap. I would say go with a z6 good motor you could find those cheap.
Old 10-29-2003, 02:22 PM
My goal on hp is 400 if it can be done. money is really not and option
Old 10-29-2003, 02:30 PM
mad2nr's Avatar
i would either go with the b16 or b18 full built for turbo or nos. me and a couple of guys around my area have done this and we are reaping the benifits and kicking azz.
Old 10-29-2003, 03:57 PM
Default Re: (mad2nr)
Which one the b16a1 or the B18? Remember I want to keep my tranny but if I have no choice in it, I'll change it. I just don't want to cut anything to fit in. What do you think about the h22a the prellude motor?
Old 10-29-2003, 04:00 PM
pennies_hatchie's Avatar
Default Re: (knighthawkacc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by knighthawkacc &raquo;</TD></TR><TR><TD CLASS="quote">Which one the b16a1 or the B18? Remember I want to keep my tranny but if I have no choice in it, I'll change it. I just don't want to cut anything to fit in. What do you think about the h22a the prellude motor?</TD></TR></TABLE>
h22 motor wont fit your tranny...
your tranny will only fit D-series motors...
so you cant put in a b16 or a b18 because they're b-series nor a h22 because its an h-series..get it
your best bet is to do a mini-me swap or to get a complete d16z6 or d16y8 or d15b etc.
Old 10-29-2003, 04:10 PM
ScottEK's Avatar
Default Re: (pennies_hatchie)
Mini-me or D15 that is going to make his 400HP? You might want to re-evaluate your goals. Obviously money does make a difference so decide how much you want to spend and a more realistic HP goal.
Old 10-29-2003, 04:18 PM
But can a h22a moter fit without cutting, If so I'll just change the tranny
Old 10-29-2003, 07:18 PM
90CRX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by knighthawkacc &raquo;</TD></TR><TR><TD CLASS="quote">But can a h22a moter fit without cutting, If so I'll just change the tranny</TD></TR></TABLE>
Nope. I've seen a handfull of h22 swaps, they all had cuts and welded mounts. It can be made to blend in. If money really isn't an issue get the H22 with internals for boosting and a supercharger. Then see what you need from there to make 400HP.
Old 10-29-2003, 07:22 PM
brent_G's Avatar
Default Re: (90CRX)
he could make 400hp on a z6 for about 3 seconds on 25lbs of boost
Old 10-29-2003, 07:24 PM
JrCRXHF's Avatar
Default Re: (screamincivik)
just go with a B16 or B18 or H22 because the tranny's are much better there are guys maken over 600whp on stock tranny and axles
Old 10-31-2003, 02:33 AM
Default Re: (JrCRXHF)
Ok I made my choice I'm going with the b16a. Can u give me a run down of everything i should swap.
Old 10-31-2003, 03:07 AM
bigworm1126's Avatar
yo if you wanna go with the minime i got a head with a everything on it and a aem cam gear ill let ig go for $100+ shipping its a fast swap and it will give you alil somethin somethin till you get your swap let me know man
bigworm1126@aol.com
ps don fake on the single cams... they can be real quick
Old 10-31-2003, 03:44 PM
90CRX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by knighthawkacc &raquo;</TD></TR><TR><TD CLASS="quote">Ok I made my choice I'm going with the b16a. Can u give me a run down of everything i should swap.</TD></TR></TABLE>
Try starting a new post. That should help you with answers as more people will read it if they have any good input for you.
Old 10-31-2003, 03:51 PM
** OF HAZARD's Avatar
Default Re: (90CRX)
stay single cam build and turbo!!!
Old 11-02-2003, 08:56 AM
Got a ? for you got a deal on a 96 b18a. can it fit without cutting
Old 11-02-2003, 03:10 PM
JDMVTEC's Avatar
DOHC ZC uses same tranny wiring and mounts and its a cheap little motor and pretty fast.
Old 11-02-2003, 06:21 PM
IDGAF2885's Avatar
Default Re: (JDMVTEC)
I say you read on this website for a while and learn more about Hondas before you make any decisions. And if money isnt a problem than I dont see why you have a Honda, much less want to make it have 400 hp.
Old 11-02-2003, 06:30 PM
mugenwannabe's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMVTEC &raquo;</TD></TR><TR><TD CLASS="quote">DOHC ZC uses same tranny wiring and mounts and its a cheap little motor and pretty fast.</TD></TR></TABLE>
too bad nothing is made for the zc
Old 11-02-2003, 06:35 PM
Skoobie no more...
HatchBox's Avatar
Default Re: (90CRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90CRX &raquo;</TD></TR><TR><TD CLASS="quote">
Try starting a new post. That should help you with answers as more people will read it if they have any good input for you.</TD></TR></TABLE>
are you crazy....listing what you need for a b16 swap has been cover numerous time...try searching before you post
Old 11-03-2003, 07:50 PM
90CRX's Avatar
Default Re: (ind3ciso)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ind3ciso &raquo;</TD></TR><TR><TD CLASS="quote">
are you crazy....listing what you need for a b16 swap has been cover numerous time...try searching before you post </TD></TR></TABLE>
true. or he could check out the hybrid section. there's a sticky for common swap info.
CarBoyEnthusiest
20
11-11-2005 08:32 AM
illogic65
08-29-2004 02:17 PM
Festinatio_Proeliator
22
07-14-2004 02:31 PM
Mister Fixer
06-23-2003 03:20 PM
aVstAr
20
01-30-2003 12:21 AM
Quick Reply: engine swap for CRX 90
