Key won't turn... - Honda-Tech
Key won't turn...
Old 10-03-2008, 06:03 PM   #1
g2tegsown's Avatar
Default Key won't turn...
Alright so I go to start my car today and the damn key won't turn... after messing with it for a bit it turns and the car starts. I get to work and try and turn the car off, and the key it stuck in the on position. So after F**king with it for awhile I get it to turn off. Now everytime it's the same situation...
It's acting kinda like the steering wheel is locked but it's not... And it's bending my key trying to turn it off, I have to actually leave it on the 1st dot instead of turning it all the way off.
Any ideas?
g2tegsown is offline   Reply With Quote
Old 10-03-2008, 06:10 PM   #2
zrickety's Avatar
Default Re: Key won't turn... (g2tegsown)
ignition lock is probably on it's way out...get a new one from honda
zrickety is offline   Reply With Quote
Old 10-03-2008, 06:11 PM   #3
Ak_ef9's Avatar
Sound like your using the wrong key. I have done that with my car a few times. Having 3 honda keys that look the same on the same key ring sucks
Ak_ef9 is offline   Reply With Quote
Old 10-03-2008, 06:46 PM   #4
g2tegsown's Avatar
Default Re: Key won't turn... (Ak_ef9)
Quote:
Only car key on the ring is my rex... it's never been the wrong key...
I'm sure zrickety is probably right. Won't I need a whole new key and lock assembly?
Old 10-03-2008, 10:34 PM   #5
guysensei's Avatar
It could be either or it could be your key is worn and lost its shape so its getting stuck or it could be that your switch is on its way out.If you can find a switch with a key swap it. If not take the switch out and take it to a locksmith it could just need a little grease and a new key. Good luck on this one.
guysensei is offline   Reply With Quote
Old 10-04-2008, 12:32 AM   #6
Pee Wee's Avatar
you can get them from autozone for cheap, and they come with keys
Pee Wee is offline   Reply With Quote
Old 10-04-2008, 02:53 PM   #7
tico's Avatar
get a new one from Honda.(highly reccomended) take it to a legit locksmith and have them match ur existing key to the new lock.
tico is offline   Reply With Quote
Key won't turn in igntion minguswooten Honda Civic (2001 - 2005) 6 05-04-2013 09:08 PM
Car Wont Start ? Relay Maybe? Help? Anyone? BlazeTeck2000 Honda Accord (1990 - 2002) 4 12-08-2005 04:39 PM
car won't star (searched) crx_of_fury Honda CRX / EF Civic (1988 - 1991) 1 06-02-2005 04:04 PM
accord egnition swich ????? alb_accord Honda Accord (1990 - 2002) 5 12-17-2003 02:35 AM
HELP !!Car wont turn off after taking the key out. IdotheSHOCKER Honda Civic / Del Sol (1992 - 2000) 4 06-16-2002 06:32 PM
Tags
03, 2002, 2003, accord, civic, element, honda, ignition, jazz, key, park, pilot, stuck, turn, wont, wrong
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
