installing inline fuel pump, where is the relay
i'm trying to install my airtex inline pump but can't find the fuel pump relay. i know it's some where by the fuse box, i can hear it clicking when i turn the ignition on but dont know which on it is. does any have any picture of what the relay looks like. which wire do i tap into and should i use another relay for the inline pump or just tap the line directly to the factory relay.
thanks,
thanks,
Re: installing inline fuel pump, where is the relay (rice4life)
It is almost right behind the hood latch release. Held on by a 10mm bolt and a U-shaped bracket I believe. Also almost right underneath the coin box thing that flips down right there.
Search for Main Relay if this doesn't help you out.
Alex
Alex
Re: installing inline fuel pump, where is the relay (Quik89Si)
is this the relay? also, which wire is the one that i use for the pump (+). there is four wire comming out off the relay.
Re: installing inline fuel pump, where is the relay (Zit)
i didn't use the relay wire...i hooked the + wire to the ignition wire under the dash
Re: installing inline fuel pump, where is the relay (zcivic91)
i very rarely have the ign on if the car is not started...it is on the ign wire not the acc wire with the radio and stuff...it's been like this for a while...the key has to be in the second position for the pump to come on
Re: installing inline fuel pump, where is the relay (NoPowerAllRice)
i plan to get a msd inline pump...im getting it cuz ill be running n2o..
i was thinking that i could connect it to a switch so i can run it only during hard driving conditions and using the n2o.
that way it wont be on all the time.but...when it is off will my stock pump have to push harder to get through the inline pump??
lemme know
lemme know
Where would be a good place to put the inline? I saw over at forced Iduct that a guy had it in between the fuel filter and rial.
Re: installing inline fuel pump, where is the relay (TEAM GARAGE SHIFTDOWN)
yea im going to put it there also the use 2" black rubber plumbing connection and zip ties to tie it to the strut bar...less vibration
uhh that dont look like mine but thats where it is at u should buy another relay from radio shack to activate ur second pump...do a search in forced induction arturbo made a post how to wire it....it works very well
Guest
Posts: n/a
Re: installing inline fuel pump, where is the relay (jdmb18hatch)
inline pump hoked up to ignition could burn out the pump. whats it pumping... fuel from stock pump... whats the stock pump pumping when the relay doesnt turn on, nothing.. not suposed to dry pump fuel pumps
I you have an Inline pump, will it be hurt by anything if your have it on a switch and only run the stock pump, then turn the inline on when im fixing to spray?
civic89si666
20
12-21-2009 10:25 PM
boosteddohczc
10
06-11-2009 09:57 PM
hatchback_al
10-26-2004 10:00 AM
