Innter tie rod / Rack end bushing problem?
Inner tie rod / Rack end bushing problem?
Here is the deal. my passanger side inner tie rod has a lot of up and down play im thinking its the rack end bushing. is this most likely the problem? The car drives really straight but you can hear the tie rod clunking at higher speed 40-65
Modified by Magick211 at 9:38 PM 10/24/2006
Re: Innter tie rod / Rack end bushing problem? (Magick211)
im glad you read this thread already.
https://honda-tech.com/zerothread?id=1117870
the inner tie rod itself should be able to ROTATE up and down. however without play. but i dont think thats what you mean. you mean the part of the rack on the passenger side is able to move up and down, right? so if thats the case, then yes it cant be anything but a bad rack end bushing.
you need to replace it. and dont forget to retighten the pinion gearbox before youre done.
are your boots ripped too? it accelerates the wear. its just plastic.
Re: Innter tie rod / Rack end bushing problem? (Tyson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson »</TD></TR><TR><TD CLASS="quote">
.</TD></TR></TABLE>
Yes it moves up and down really easy, also the boot is torn and the car has 280k on it
.</TD></TR></TABLE>
so then its a no brainer.
all my advice and tips are in that thread. please read it carefully.
good luck. id love to hear your feedback once its done.
Oh ok thanks for clearing that up i was about to go to the parts store to get it guess ill go to the dealership and get the correct one.
Mr. Em1
21
06-07-2010 03:24 PM
