injector question
Re: injector question
runs fine is not the same as runs right. d15b7 is obd1 so you still need to remove the resistor box. saturated injectors are considered better than peak/hold injectors, so nothing wrong with using OBD1 injectors. just the resistor box has to go.
Ok then not from the b7 because obd1 has different plugs... i had them laying around and they worked... i dont want to have to chop up the harness.. yet.
Randysi
04-04-2012 10:17 AM
pinecone
04-25-2006 06:41 AM
