ignition switch/toggle switch issue
Im having issues installing a toggle switch and pivot push button start. My key no longer fit my tumbler and starting having ignition problems shorting out my fuse box and other electronics. mainly coil and draining battery.
Im trying to install a toggle switch for acc and ign on and push button start for starter. I have a wiring diagram and still stumped because the white/red go to ignition and doesnt show in my haynes manual to go to anything.
and if your wondering why i just didnt replace key tumbler and ign switch because the ignition switch costs 65 bucks and whole key set from honda costs 278 bucks if its not discontinued.
Re: ignition switch/toggle switch issue
The switch and the lock cylinder are 2 different things, but it sounds like both are broken? You can get both new for about $100 or less if you go to the junkyard. You will just need a second key. Don't try your wacky switches and buttons, just fix it right. Your battery drain could be related, or something else entirely. The ignition switch new from honda is cheaper than autozone. GL
