ignition switch color codes ASAP - Honda-Tech
Old 07-03-2004, 02:02 PM   #1
spooned out's Avatar
Default ignition switch color codes ASAP
Help installing a turbo timer and i need help from anyone who knoes the wire colors .... does anyone have a diagram of the igntion switch? i need to knoe which is which........ ACC ON IGN1 IGN2 12v ...... and can you confirm what the purple wire connects too? is it SPEEDOMETER OR RPM?
did search but did not find one for ef models
ASAP
spooned out is offline   Reply With Quote
Old 07-03-2004, 03:39 PM   #2
vhd
vhd's Avatar
Default Re: ignition switch color codes ASAP (spooned out)
bat-a(12v.) from fuse box=wht/blk
ign1 = blk/yel
ign2-a = yel
ing2-b = blu/wht
acc = wht/red
start = blk/wht
key on should be ign1. i think you mean blue and not purple, cause there is no purple wires. it should be blue for rpm
vhd is offline   Reply With Quote
Old 07-03-2004, 04:06 PM   #3
Default Re: ignition switch color codes ASAP (vhd)
thanks for the quick response...... the purple i was referring to from the turbo timer..... does it hook to the rpm or speedo?
Old 07-03-2004, 04:11 PM   #4
Keyboard Humorist
4drEF's Avatar
What does the instructions tell you to hook it to?
4drEF is offline   Reply With Quote
prestige aps997n Install help! EFPimpin Audio / Security / Video 6 09-17-2010 04:55 AM
Eg side maker wiring doobiesack23 Honda Civic / Del Sol (1992 - 2000) 13 01-10-2005 11:52 PM
GROUND WIRE KIT AZNBIGPIMPN505 Honda Civic / Del Sol (1992 - 2000) 11 12-03-2004 01:10 AM
speedometer isnt working Luward Honda Civic / Del Sol (1992 - 2000) 2 06-15-2004 10:58 PM
will 255 inline pump work? spooned out Honda CRX / EF Civic (1988 - 1991) 2 08-16-2003 11:54 PM
Tags
1990, 90, civic, code, codes, color, crx, harness, honda, hondatech, ign1, ign2, ignition, mean, switch, wire
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
