I am Looking For DOHC ZC Vaccum DIAGRAMS
Old 05-10-2014, 03:42 PM
89brokendownEF's Avatar
Default I am Looking For DOHC ZC Vaccum DIAGRAMS
Looking For DOHC ZC Vaccum DIAGRAMS woulde like to see how others have them wired up in there ef hatch or how the vaccums are in general
Old 05-10-2014, 04:50 PM
EFB055
~sp33~'s Avatar
Default Re: I am Looking For DOHC ZC Vaccum DIAGRAMS
This is from the workshop manual. Note that this is for OBD0, OBD1 will be different (Throttle body mounted MAP sensor and a different DASHPOT setup). Also note that line #22 that connects to a little vacuum diaphragm does connect straight to one of the three intake manifold ports on some models (some don't have the throttle body mounted vac diaphragm).
Your OEM vacuum setup will depend on what country, and what year your ZC is from.
Old 05-10-2014, 04:52 PM
now to my understanding, i have to plug two vaccum lines on the intake?
if it helps i can get pictures of my setup
Old 05-10-2014, 05:08 PM
EFB055
~sp33~'s Avatar
Yeah post a pic of what you have, and what you're having trouble with.
Old 05-10-2014, 05:18 PM
there is another vaccum left of throttle body in picture, i also need to know where yellow and green wires go on the transmission. look at pics tell me what to do with vaccum lines
Old 05-10-2014, 10:35 PM
EFB055
~sp33~'s Avatar
From what i can see it looks pretty good. That extra little port on your throttle body should be connected to your MAP sensor (providing it with vacuum). The larger port at the top center of your throttle body connects to the charcoal canister (which it look like it already might be in your pics, hard to see the line routing). The three ports on the front of your intake mani look good too.
Which wires are you referring to (can't see any yellow/green wires)?
Old 05-11-2014, 04:01 AM
there are two wires that come out of transmission bell housing on transmission
Old 05-11-2014, 07:01 PM
EFB055
~sp33~'s Avatar
My guess is that you're talking about the reverse switch wires. That's the only two I can think of that connect to the housing.
Old 05-12-2014, 02:26 PM
where do they plug up tho. i cannot find where they go
Old 05-13-2014, 12:45 AM
EFB055
~sp33~'s Avatar
This is the wiring diagram, try and find the yellow wire and green/blk wire on your wiring harness.
Old 05-13-2014, 06:24 AM
i see plugs on harness behind intake minifold, but they both look like female connectors. the wires on trans case seem to be male/female
Old 05-13-2014, 09:19 AM
if you look at the throttle body picture, there is a port on bottom not connected, should that be plugged? there is also a port to the left underneath throttle body. should i plug them both
Old 05-14-2014, 03:49 AM
EFB055
~sp33~'s Avatar
The coolant line that comes off of your intake manifold connects to the coolant line under your throttle body (the port you're talking about). It then connects from your throttle body to your IACV (the little unit with a plug on it at the back of your intake manifold near the throttle body) before returning to your water pump inlet pipe .
Looks like you've bypassed the throttle body coolant line.
Old 05-14-2014, 03:51 AM
EFB055
~sp33~'s Avatar
Yeah they should be M/F.
Should be attached pretty close to the portion of the harness that routes under the distributor for the temp gauge sender (single wire) and the thermo sensor. If it's not there though, who knows where it could be.
Old 05-14-2014, 06:46 AM
Freemananana's Avatar
The reverse lights should come off somewhere around the area where your thermostat ground is at. Within about 12" of that location. I don't believe they are all that important. At least, they won't stop your car from driving.
Old 05-14-2014, 10:31 AM
there are two small hoses that come off of intake in back , which is coolant line
Old 05-14-2014, 01:02 PM
EFB055
~sp33~'s Avatar
If they're the ones i'm thinking of, they're both coolant lines. One is a much larger diameter, and a U shape, the other comes out next to it is maybe 10mm in diameter. That's the one that should connect under your TB.
Post a picture of the two if you can't figure it out.
Old 05-14-2014, 02:00 PM
Keyboard Humorist
4drEF's Avatar
Are you missing the dashpot control solenoid?
If you don't have it, the you can plug the line that goes from the dashpot to the intake and then discard of the dashpot (everything associated with the 6, 8, 12, 22 vacuum lines).
They sell these vacuum plugs at automotive stores.
Old 05-18-2014, 06:36 AM
jlicrx's Avatar
909ej195
01-19-2007 06:29 AM
t0eKnEe
05-18-2004 11:41 AM
crx b16a
04-08-2002 06:46 AM
Quick Reply: I am Looking For DOHC ZC Vaccum DIAGRAMS
