How tight to tighten lug nuts on wheels?? - Honda-Tech
Old 09-23-2009, 05:41 PM   #1
Icon6 How tight to tighten lug nuts on wheels??
I've heard if you over tighten it can mess up you brakes. How tight should I tighten my wheels?
michael-crxsi is offline   Reply With Quote
Old 09-23-2009, 05:44 PM   #2
90RENOsedan's Avatar
Default Re: How tight to tighten lug nuts on wheels??
you heard wrong. tighten them til you can't tighten them anymore by hand. if you're using air, tighten them til the gun stops.
90RENOsedan is offline   Reply With Quote
Old 09-23-2009, 05:57 PM   #3
seanbev24's Avatar
Huh? It's like 80-85 foot pounds.
seanbev24 is offline   Reply With Quote
Old 09-23-2009, 05:59 PM   #4
Quote:
I have a gun that you wont ever stop, it will spin away with a snapped off stud in your socket.
85 lb/ft
and yes it can warp your rotors by over torquing. You heard right
gator88 is offline   Reply With Quote
Old 09-23-2009, 06:03 PM   #5
grog's Avatar
80 lb-ft, and thats from the helm manual so thats the "official" spec.
grog is offline   Reply With Quote
Old 09-23-2009, 06:06 PM   #6
Pirate General...YARRRR
Ass$nyper's Avatar
It's 80-85, you may or may not need to adapt a few ft lbs for aftermarket wheels.
Yes lugs can be over torqued.
I'm a bit of a retentive man when it comes to this and I will not use a gun it's hand then torque wrench.
Ass$nyper is offline   Reply With Quote
Old 09-23-2009, 06:09 PM   #7
Touching My Member
.Manny.'s Avatar
I use a 3/8" impact gun at the lowest setting just to snug them. then the trusty torque wrench at 80lb-ft
.Manny. is offline   Reply With Quote
Old 09-23-2009, 06:11 PM   #8
D16SiHatch's Avatar
they should be tight, (80-85 ft/lbs ^), but i dont think i would say till you cant do it anymore by hand. if you're using a 1/2" ratchet then that might be about right. if you're using a 4-way however you could very well break off one of the studs. also, not all air guns are the same. setting the impact gun to its highest setting might not be advisable.
D16SiHatch is offline   Reply With Quote
Old 09-23-2009, 06:22 PM   #9
grog's Avatar
Quote:
is that for softer material or what? or is that just what those manufactures recommend?
Old 09-23-2009, 06:49 PM   #10
HackeN's Avatar
I use whatever. Sometimes a 3/8 socketwrench, sometimes a 1/2 impact. It's not like I sit there and hammer it down on the impact, only takes a split second or so.
But I never tighten mine too much, there's no reason to. I hate taking others off that are torqued down like crazy. Never had a problem w/ mine comming lose from the cheapest lug nuts available, to expensive ones, from stock steelies to aftermarket aluminum wheels.
People tent to over torque things thinking that it's going to fall off if they don't. It's like hearing about people snapping or stripping bolts/threads on their valve covers when they can be tightened down with your fingers basically. I personally use a screwdriver w/ 10mm socket on it to do mine just so i never do that ;x
HackeN is offline   Reply With Quote
Old 09-23-2009, 08:42 PM   #11
mother ef-er's Avatar
^ w3rd. you can overtighten your lugnuts, but you gotta be a real "musle man". with the right tools you dont have to worry. use an eletric impact and let it max for a couple seconds. really, its not that big of a deal when using good tools.
or if youre tightening lug nuts with a torque wrench, just use standard specs. its kind of a simple theory..
mother ef-er is offline   Reply With Quote
Old 09-23-2009, 09:58 PM   #12
Ass$nyper's Avatar
Quote:
To be honest I'm not sure but I've seen a few cars that aftermarket wheels ask for a few more ft lbs.
I've heard a few theories but I'll read up and try to figure it out.
Old 09-23-2009, 10:48 PM   #13
EL Vap133's Avatar
Cross tighten them.
EL Vap133 is offline   Reply With Quote
Old 09-23-2009, 10:53 PM   #14
Ass$nyper's Avatar
Cross tightening or star pattern should be assumed.. least I hope
Old 09-23-2009, 10:59 PM   #15
SLAP! your dumb
Quote:
yeah thats the spec most people go by. Honda does about 100 ft lbs. Gray torque stick
Quote:
seen it MANY times. it sucks!
yup. lol if people have rotas then yes, they NEED to me over torqued haha
apekd is offline   Reply With Quote
Old 09-23-2009, 11:01 PM   #16
Ass$nyper's Avatar
Quote:
over torqued why?
I torque both my SW388s and Slips to the same 85 ft lbs.
Old 09-23-2009, 11:07 PM   #17
^It was a joke lol I dont like rota's very much. When I was in high school 2 years ago every kid and their moms had rotas. I thought the 17's and 18's where annoying till this stage. lol
Old 09-23-2009, 11:11 PM   #18
Ass$nyper's Avatar
Oh.
I had hoped you'd be able to solve the mystery of why some aftermarket wheels request a different torquing.
Old 09-23-2009, 11:15 PM   #19
Oh.
well the torque value depends on the stud and nuts strength mainly. but when the wheel is a different material (IE Aluminum) it tends to need less as when the rotor heats up the heat passes into the wheel. heat will soften the rim meaning you can actually warp the wheel if the studs are too tight. I know there is more info on this than my $.02 worth
Old 09-23-2009, 11:17 PM   #20
Ass$nyper's Avatar
That's what I assumed but a few cars I've had the aftermarket rims made sure to note using MORE ft lbs then OEM.
That's what I'm rather perplexed about.
Old 09-23-2009, 11:19 PM   #21
hmmm...i never really see MORE than OEM. maybe its so the weakling thiefs out there cant steal the rims?
Old 09-23-2009, 11:23 PM   #22
Ass$nyper's Avatar
LMFAO
Old 09-23-2009, 11:27 PM   #23
lol
I know that Blox extended studs need less from what I remember. Not sure if its just cause they are POS studs and break fast, or something else
Old 09-24-2009, 01:55 AM   #24
theft24's Avatar
tighten till it bottoms out then 4-6 hits after that
theft24 is offline   Reply With Quote
Old 09-24-2009, 07:43 AM   #25
dacrxguy's Avatar
wow i would never let you work on my car the spec is 80ftlb ii hope you never use a 500ftlb gun
some manufactures recommend cheking the tourque after 20 miles on aluminom wheels
dacrxguy is offline   Reply With Quote
Timing belt replace, not tight. yankie_1132 Honda Accord (1990 - 2002) 2 04-17-2012 04:33 AM
Oil Pan Gasket JFG Kevin Tech / Misc 8 06-19-2007 08:33 PM
For those of you using TunerToys oil pressure sender fitting... GetawayInMoscow Forced Induction 6 03-24-2007 01:39 PM
Why do dealerships tighten oil filters so tight? J Rob General Discussion and Debate 16 08-02-2006 10:43 PM
Tightening Alternator belt 98TypeR Acura Integra Type-R 2 01-31-2004 05:41 PM
Tags
80, 99, accord, aluminum, car, lbft, lbs, lug, lugs, nuts, tight, tighten, tightening, torque, wheels
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
