How tight should Rocker arm be when adjusting valve??? - Honda-Tech
Old 07-05-2003, 07:23 AM   #1
hondaless's Avatar
Default How tight should Rocker arm be when adjusting valve???
Ok since i changed injectors and the timing couldn't be any better my valves have to be making the noise.... when i adjusted them the rocker arms or those things the lobes on the camshafts hit are a lil loose.... should they be loose or a lil tight???
hondaless is offline   Reply With Quote
Old 07-05-2003, 07:40 AM   #2
ComposiMo's Avatar
Default Re: How tight should Rocker arm be when adjusting valve??? (evilcrx)
Quote:
Dude, maybe its time to take the car somewhere and let someone who knows what they are doing adjust the valves for you. You can hurt your engine badly if you make a mistake up there.
What did you adjust them to when you did it (what feeler thickness did you use)?
ComposiMo is offline   Reply With Quote
Old 07-05-2003, 07:50 AM   #3
hondaless's Avatar
Default Re: How tight should Rocker arm be when adjusting valve??? (ComposiMo)
.15mm intake .17mm exhaust
Old 07-05-2003, 08:13 AM   #4
jung4g's Avatar
Damn, all metric and shitt... I adjust both my intake and Exhaust to .009 inches... Per the Honda service manual you should adjust them to .17mm-.22mm intake and .22mm-.27mm exhaust. So you may have them a little tight, and they can go to smaller clearance when you're tightening the lock nut, so be careful, to tight can cause some weird stresses in there... Good luck...
Jung
jung4g is offline   Reply With Quote
Old 07-05-2003, 08:17 AM   #5
hondaless's Avatar
Default Re: How tight should Rocker arm be when adjusting valve??? (jung4g)
thats what the honda manual recomends for a ZC and if it was to tight wouldn't it idle like crap? the car idles fine just a lil noisy.
Old 07-05-2003, 08:22 AM   #6
Vinceg99's Avatar
Quote:
That doesnt make any sense?? You tell him that he may have them a little tight yet what he tightened them to is less than what you said the manual says??
Vinceg99 is offline   Reply With Quote
Valve clearance quandry user456101 Honda Accord (1990 - 2002) 1 02-02-2017 02:54 PM
Rocker very tight against valve? remix919 Honda Accord (1990 - 2002) 1 01-04-2017 02:30 PM
H23 Rocker Arm Play no1knows908 Honda Prelude 6 10-11-2007 11:58 PM
WTB: DOHC ZC Cylinder Head TheDR Want to Buy 3 12-16-2005 11:46 AM
Problem with valve adjustment? cool Hybrid / Engine Swaps 1 08-27-2002 08:44 AM
Tags
adjust, adjusting, arm, arms, civic, doch, honda, installation, loose, nut, rocker, rockerarm, rockers, tight, valves, zc
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
