How to test evey component in your distributor - Honda-Tech
Closed Thread
Old 03-15-2011, 03:38 PM   #1
Default How to test evey component in your distributor
How to test a distributor(not just the coil)
When you are are having a problem with spark or driveablity of your car due to a distributor related CEL there are a few things to check not just the coil. Every sensor coil and ignitor can be tested. So lets go through it.
If you have no spark at all and your ecu fuse isnt blow you should first test the coil before you try an ecu or anything like that. You will need an ohmmeter for this. So remove the cap and rotor and the plastic sheild and here is the test.
I dont think this needs much explaining. Its very easy even if you never used an ohmmeter before. Just to be safe thought I would unplug the distributor as . If this checks out and you still have no spark the next step would be to check the igniter. Here is the test for that.
This test can set you in the right direction if the distributor isnt the issue at all. The yellow green or thick white on obdo should have power and if it doesnt check it for continuity. If there is no continuity it would indicate a break in the wire or poor wiring. If there is continuity and no power that would indicate a problem with a ground, bad ecu, bad fuse.
To test the crank,tdc,and cyp sensors unplug the distributor and on the distributor size of the plug test for resistance between the terminals of each individual sensor. They should test between 350 and 700 ohms depending upon temperature. If you have a CEL form one of these sensor and they are between the specified resistances then the problem is in the wiring. So there you have it. If you think that your distributor is bad here is a sure fire way to find out,
rollinswapshop is offline
Old 03-15-2011, 04:11 PM   #2
EL Vap133's Avatar
Default Re: How to test evey component in your distributor
Posted two threads..
EL Vap133 is offline
Closed Thread
DIY: How to test for spark and to troubleshoot spark problems Former User Honda Civic / Del Sol (1992 - 2000) 17 08-19-2016 10:34 AM
92 Honda Civic NO SPARK **FOLLOW UP** Noo_Ish_mee Honda Civic / Del Sol (1992 - 2000) 7 06-27-2016 03:44 PM
1992 Honda Civic DX won't start chariseGH Honda Civic / Del Sol (1992 - 2000) 20 06-15-2015 07:19 PM
1992 Civic LX 4 door no spark nrk Honda Civic / Del Sol (1992 - 2000) 17 04-14-2013 06:09 PM
How to test evey component in your distributor rollinswapshop Honda CRX / EF Civic (1988 - 1991) 4 03-16-2011 08:43 PM
Tags
96, accord, bad, check, checking, civic, components, distributor, distributors, dx, ef, honda, igniter, resistance, tech, test, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
