How to replace valve seals?
Old 04-07-2011, 12:38 AM
///Mathew's Avatar
Default How to replace valve seals?
I've got a b18a1 for my civic that I partially disassembled and now am reassembling, so I bought a top end gasket kit, including head gasket, exhaust, intake etc.
The kit also came with valve seals and I was wondering how easy it is to install them. I don't have any specialty tools nor the experience to remove the valves/springs etc. I was wondering if the valve seals can be replaced without getting in too deep.
Thanks guys.
Old 04-07-2011, 03:50 AM
CWBETB's Avatar
Default Re: How to replace valve seals?
Looking for some answers on this also. Nice build btw
Old 04-07-2011, 03:57 AM
Old goat's Avatar
https://honda-tech.com/forums/showth...e+seal+removal
Old 04-07-2011, 07:48 AM
Keyboard Humorist
4drEF's Avatar
As an alternative for those that don't have shop air or a leakdown tester, you can rotate the crank so that the piston is all the way down and fill the cylinder with nylon rope. When it's full, then turn the crank slowly to compress the rope and keep the valves up. It works, harms nothing, and is a recommended method if you don't have shop air.
Old 04-07-2011, 07:58 AM
turtleman321's Avatar
^^^ that's correct. Use it all the time.
One problem he doesn't have specialty tools to remove the valve springs and retainers
Old 04-07-2011, 09:59 AM
CRX Toad's Avatar
And use one of these it makes things so simple. http://www.tooltopia.com/lisle-36050.aspx you will thank yourself. That with either air or nylon rope will make it a snap.
Old 04-07-2011, 10:38 AM
Keyboard Humorist
4drEF's Avatar
Also, you need a set of bent feeler gauges rather than straight ones to set the valve lash.
Good time to put in a new cam as well
jdm_sai
05-08-2020 09:29 PM
live4soccer7
17
07-01-2019 06:44 AM
GaryTuesday
10-26-2013 09:57 AM
bllabong89
03-30-2009 12:59 PM
MisterB
06-04-2003 09:31 PM
Quick Reply: How to replace valve seals?
