How to know if your ball joints are bad & how to check for it? - Honda-Tech
Old 06-29-2011, 11:29 PM   #1
Default How to know if your ball joints are bad & how to check for it?
I need that information.
I have the Chilton manual but it only says "if the ball joint is defective the entire upper control arm must be replaced."
90efzc is offline   Reply With Quote
Old 06-29-2011, 11:54 PM   #2
Tyson's Avatar
Default Re: How to know if your ball joints are bad & how to check for it?
if the boot is torn and looks like its been torn for a long time, or this is the first time you ever bothered to look, its almost certainly in need of replacement.
for the upper balljoint, you grab the knuckle and just shake. put your other hand around the balljoint and youll feel the play.
the upper balljoint needs to be replaced with the entire arm because honda never sold just the balljoint. you can get just the balljoint aftermarket, AS LONG AS you have the pressed on type of arms. some earlier arms have the balljoint welded on. it should be obvious to distinguish... but even after pressing a new balljoint and securing it with a circlip, its a good idea to spot weld it.
honestly, i think its better to just replace the whole arm... you get new bushings from honda with the new arm.
Tyson is offline   Reply With Quote
Old 06-30-2011, 12:34 AM   #3
Alright thank you.
Old 06-30-2011, 04:50 AM   #4
1990edsedan's Avatar
to check the lower ball joint, take a long pry bar and insert the end in between the knuckle and the lower arm and try to pry them apart. If your ball joint has play it will move a bit. This has to be done while the front end is up on stands - not on the ground.
1990edsedan is offline   Reply With Quote
Ball Joints and Bushings Tylooch Honda CRX / EF Civic (1988 - 1991) 16 03-18-2012 04:53 PM
how to pop Lower Ball joint back into place? Mendes Honda Civic / Del Sol (1992 - 2000) 8 02-23-2008 02:45 PM
ball joints? tigueremalo Honda CRX / EF Civic (1988 - 1991) 2 07-05-2006 07:33 PM
ball joint boot question? teawoboba Tech / Misc 3 06-16-2004 10:58 AM
ball joint removal wanttorace Tech / Misc 6 12-10-2002 08:19 PM
Tags
2002, accord, arm, bad, ball, bushing, check, civic, control, honda, joint, joints, lower, play, replaced, signs
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
