how to get the axle nut off when its stripped?
Whats the best way to get the axle nut off? its kind of stripped a little. Should i heat it up. Or just cut the axle off(i dont really need the bearing and other stuff)
Screw you guys, I'm... going... home.
Re: how to get the axle nut off when its stripped? (madmanmulligan)
Weld something to it like a socket or a piece of pipe. Then turn THAT. If you have good access to it use a cold chisel and crack the nut. It should come off fairly easily after that.
try to smash a smaller socket on the nut and impact it
mack sure the axle lock thing is moved out of the way
Re: how to get the axle nut off when its stripped? (crxsteve)
^he's right. make sure that you hit out the part of the axle nut that is hammered into the divit on the axle itself. you should get a new nut as it is with your axle if you're changing it out. good luck.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by madmanmulligan »</TD></TR><TR><TD CLASS="quote">any other ideas? </TD></TR></TABLE>
I've used a dremel to cut most of the way through then a chisel to finish it off. It took about 10 minutes and I didn't break a sweat
1 Post
have you got a decent impact?
what does "kind of stripped" mean? if it isn't too bad a 6point socket should pull it off in an impact. if that spins, i'd first try to find a slightly smaller socket that you could hammer onto it and impact it off that way.
if it is stripped worse than that, then we'll have to get a little more creative.
EDIT: damn you guys type fast.
the cutoff wheel/ dremel would be my next route
Re: how to get the axle nut off when its stripped? (EL Vap133)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EL Vap133 »</TD></TR><TR><TD CLASS="quote">An act of God? </TD></TR></TABLE>
o vap.....
o vap.....
Re: how to get the axle nut off when its stripped? (Lost_in_a_world_so_cold)
thanks for the help guys
my impact gun broke last week so i used a demel tool, it worked
LS94tegra
04-19-2008 11:59 AM
dynamo
13
11-14-2005 08:22 PM
EFM_ookie
16
08-14-2005 09:27 PM
