How to fix a FITV its as easy as 1, 2, 3.... - Honda-Tech
Old 12-07-2003, 11:03 PM   #1
Nerologic's Avatar
Default How to fix a FITV its as easy as 1, 2, 3....
many of you guys have had idle issues, and alot of the times its the FITV tahts messing everything up, and know im going to show you guys how easy it is to fix the situation....it was easier the i thought...
here is a picture of the problem its unscrewed and not it place (opened FITV)
here is another shot right after i took off the cap (its not supposed to be flesh with the end of the unit)
all you really need to do is screw back in the middle section back on tight (see the too open sections on the edge of the inner part, the white part) and your set here is the thing empty
so when your sone screwing the FITV and everything is tight and cleanded properly it should look like this
now just put the cap back on pretty tight and make sure it seals good and everything, then put it back on the manifold and plug in the 2 coolant lines and you now can idle under 3k rpms...sorry for the bad explenation but i guess sthe pics make up for what i lack in
Modified by Nerologic at 8:48 AM 5/8/2004
Nerologic is offline   Reply With Quote
Old 12-07-2003, 11:14 PM   #2
Default Re: How to fix a FITV its as easy as 1, 2, 3.... (Nerologic)
bossman032 is offline   Reply With Quote
Old 12-08-2003, 01:02 AM   #3
bseriesboosted's Avatar
great post
bseriesboosted is offline   Reply With Quote
Old 12-08-2003, 03:59 AM   #4
FourthGenHatch's Avatar
Pics don't work. What is a FITV anyway?
FourthGenHatch is offline   Reply With Quote
Old 12-08-2003, 04:42 AM   #5
SiZ
SiZ's Avatar
Thanks!
SiZ is offline   Reply With Quote
Old 12-08-2003, 06:19 AM   #6
kim_2_da_chee's Avatar
Default Re: How to fix a FITV its as easy as 1, 2, 3.... (SiZ)
top notch
i think you just helped a whole lot of crx/ef owners
kim_2_da_chee is offline   Reply With Quote
Old 12-08-2003, 08:59 AM   #7
Nerologic's Avatar
village photo is being gay and imagestation is is down and we todd hasnt given me a pass word yet so i need to upload the pics again...ha, i just realized i left out the whole 1 2 3 idea...oh well
Old 12-08-2003, 10:17 AM   #8
bump b/c i wanna know!
b16_madman is offline   Reply With Quote
Old 12-08-2003, 10:22 AM   #9
88DXCRX's Avatar
Location: I told you to wait in the truck in Texas, United States
Default Re: (Nerologic)
Try H-P photo located @ *click here*
No more RED X's and plenty of storage space and of course,its free!
88DXCRX is offline   Reply With Quote
Old 12-08-2003, 10:44 AM   #10
virginia_dude's Avatar
Default Re: How to fix a FITV its as easy as 1, 2, 3.... (FourthGenHatch)
Quote:
I have the same question, never heard of it before.
virginia_dude is offline   Reply With Quote
Old 12-08-2003, 01:06 PM   #11
Nerologic's Avatar
Default Re: How to fix a FITV its as easy as 1, 2, 3.... (virginia_dude)
here is the FITV right under the TB
here is a closer shot of it
its only found on OBD0 manifolds from what i know of, and it controls the idle when its warm and when it is cold, and it changes it depends on the warmth of the coolnant, so basically whne ur coolant is warm (engine is warm) and idle goes down
Modified by Nerologic at 8:51 AM 5/8/2004
Old 12-08-2003, 03:37 PM   #12
LD_EGSICK's Avatar
what else is compatible with the jdm b16a? could i use the one from my old si motor?
LD_EGSICK is offline   Reply With Quote
Old 12-08-2003, 07:18 PM   #13
Nerologic's Avatar
ya you can use any FITV, i used one from a prelude, all i had to do is change the end cap for the coolant lines because it was different, that why in the pic the end is dirtier then the rest of it
Old 12-08-2003, 07:21 PM   #14
Default Re:
I don't think my ZC has one of those things. Is it only B-series that does?
Old 12-08-2003, 10:31 PM   #15
Nerologic's Avatar
y i think its just on OBD0 bseries motors like lude's integs and b16's......
Old 12-08-2003, 10:38 PM   #16
Rywire's Avatar
I have seen them connected to the t-body on newer b16's. Ryan
Rywire is offline   Reply With Quote
Old 12-09-2003, 12:09 AM   #17
fourthgenhatchB17's Avatar
Default Re: (droppedcrxsi)
Quote:
Yes true, there is one on my OBD-1 B17. I couldnt see the pics either and would like to know how to fix my FITV, because as of right now i have it plugged. I have taken the cap off of it before and i saw no screw to adjust. Where is the screw?? or do i just screw the entire unit that i see (when the cap is off) until its flush with the rest of the FITV? Wish those pics showed up for me...
fourthgenhatchB17 is offline   Reply With Quote
Old 12-09-2003, 12:42 AM   #18
rice_classic's Avatar
I don't have an FITV. I put on a skunk2 mani with a 68mm TB and GOODBYE FITV. So now when I start my car I just hold the gas pedal down and let it idle at 1200 for a one minute before I drive it.
Only really cold morning starts I would always let it idle for 1 minute before I drove it anyway. That's with it in neutral and clutch engaged so I can get the tranny gears lubed as well.
BTW: removing the FITV for me didn't change my hot idle.. only my cold idle.
rice_classic is offline   Reply With Quote
Old 12-09-2003, 09:06 AM   #19
KoRE's Avatar
Default Re: (rice_classic)
FITV only contorl COLD Idle the IACV controls the Warm Idle...
I'm pretty sure that's the way it works
KoRE is offline   Reply With Quote
Old 12-09-2003, 10:32 AM   #20
that first picture my OBD1 manifold also has it Xsi 92-93
I just notice that because my other manifold don't have it
soo I am gussing the OBD0 and OBD1 which came out of Xsi 92-93 OBD1 has it also I don't know about the civics
Old 12-10-2003, 12:04 AM   #21
Nerologic's Avatar
Default Re: How to fix a FITV its as easy as 1, 2, 3.... (bossman032)
ya u basically spin the whole unit around in, notice that its more in then in the first 2 pic, tighten the thing as much and you can....sorry about the X's village photos was being gay and i finally found a good host.. 88DXCRX for the host suggestion they pulled through...any other questions?
Old 12-10-2003, 05:26 PM   #22
Nerologic's Avatar
bump for the motor mount....
Old 12-11-2003, 11:52 PM   #23
Nerologic's Avatar
second bump for the motor mount,anyone??
Old 01-02-2004, 08:35 AM   #24
SPORT INJECTION's Avatar
what does FITV stand for?
SPORT INJECTION is offline   Reply With Quote
Old 01-02-2004, 08:49 AM   #25
crxluv2's Avatar
Default Re: (SPORT INJECTION)
Fast Idle Thermo Valve
crxluv2 is offline   Reply With Quote
Surging Idle? How-To Tech Article...(56k beware) honda_power69 Tech / Misc 198 12-04-2013 07:08 AM
Ohlins! Transport Acura Integra Type-R 9 11-10-2004 05:02 AM
94 Accord EX Crashed...Who Wants What??? junglerunna Honda Accord (1990 - 2002) 455 11-03-2004 03:40 PM
FS: Mugen Seat, CTR SRS wheel, TAKATA Harness (56K might have a small wait) 00-ITR-373 For Sale 234 11-21-2003 04:01 PM
FS: D16Z6 head and intake manifold and 92-95 civic haynes manual DSeriesBeeKilla For Sale 0 07-12-2003 04:41 PM
Tags
2001, 93, accord, civic, cost, crx, d16y8, fast, fitv, fix, honda, idle, part, thermo, valve
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
