how do i know what obd my b18b1 is sorry new to this - Honda-Tech
Old 01-23-2012, 08:48 PM   #1
Default how do i know what obd my b18b1 is sorry new to this
idk if its obd0, obd1, obd2 please help
jake12ryder is offline   Reply With Quote
Old 01-23-2012, 08:54 PM   #2
88HATCH(:'s Avatar
Default Re: how do i know what obd my b18b1 is sorry new to this
looks to be obd0.
88HATCH(: is offline   Reply With Quote
Old 01-23-2012, 08:55 PM   #3
wreckin-rex91's Avatar
It's all in the dizzy! Check your ECU type too ... That makes it easy
wreckin-rex91 is offline   Reply With Quote
Old 01-23-2012, 09:17 PM   #4
alright thanks guys appreciate it
Old 01-23-2012, 09:33 PM   #5
the valve cover is OBD2, if the motor has a vin number on it, its OBD2.
B18b1 was only made in OBD1 and 2, not 0
the dizzy and ECU can all be changed to work with the motor. You can have a motor from the 96+ (obd2) cars and be running obd1 or obd0
If you are asking if your car is set up to be OBD0,1, or 2, then check the ECU.
alex14 is offline   Reply With Quote
Old 01-25-2012, 08:12 AM   #6
how can i tell on the ecu... the ecu is a pr4
Old 01-25-2012, 08:20 AM   #7
DO IT ON ALL FOURS
OneBadTurboCRV's Avatar
Just look at the plugs...
OneBadTurboCRV is offline   Reply With Quote
Old 01-25-2012, 08:25 AM   #8
Quote:
thanks man i will have to check it out when i get off
Old 01-25-2012, 09:28 AM   #9
codybuRr's Avatar
you realize b18a and b18b have the same internals, you can convert up and down between obd0 thru obd2.
its all in the wiring and ecu that you use.
codybuRr is offline   Reply With Quote
Old 01-25-2012, 09:33 AM   #10
Of coarse.
Old 02-14-2014, 05:31 PM   #11
i have a b18a1. no sure what obd it uses but i could just use a obd1 harness and and ecu and it'll all work out?
myownworstenemy is offline   Reply With Quote
Old 02-15-2014, 07:43 AM   #12
Spug's Avatar
Quote:
You would need an OBD1 Dizzy and ECU, as well as the ECU jumper harness if you choose to use one.
Spug is offline   Reply With Quote
Type r swap in eg??? EG*RYDER Honda Civic / Del Sol (1992 - 2000) 3 09-14-2011 07:56 AM
obd0 to obd1 Jedi Jake Honda Civic / Del Sol (1992 - 2000) 0 05-03-2007 08:05 PM
97 ITR FOR SALE IN TENN. Swell_Ryder Southeast (Sales) 42 03-02-2006 09:46 PM
Need 1.6 SOHC VTEC complete swap ghost_ryder35 For Sale 3 03-03-2004 05:36 AM
ruff-ryders???????? layz1eviet Honda Motorcycles 15 11-02-2003 11:09 AM
Tags
b18b1, car, civic, cover, honda, number, obd, obd0, obd1, obd2, valve, vavle, vin, wat, year
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
