how do i flush my coolant system to get air out of the system - Honda-Tech
Old 11-04-2008, 04:42 PM   #1
tmurda253's Avatar
Default how do i flush my coolant system to get air out of the system
i was jus wonderin how to get the air pockets out of my coolant system on my singel zc. Any suggestion would help, thanks...
tmurda253 is offline   Reply With Quote
Old 11-04-2008, 04:44 PM   #2
ej8
ej8's Avatar
Default Re: how do i flush my coolant system to get air out of the system (tmurda253)
I use a vac refil tool that connects to airline and puts the system under vac and then you "suck" in the coolant until full, no air pockets
As far as the traditional ways just search, been covered many times.
ej8 is offline   Reply With Quote
Old 11-04-2008, 04:44 PM   #3
sleepingciv's Avatar
start your car up, turn the heat on defrost, take radiator cap off, on the upper radiator hose follow that to the head there will be a little 12mm nipple open it dont remove it, little bubbles should start to come out when it warms up. add fluid as needed until solid fluid comes out of the nipple. put cap back on close nipple
sleepingciv is offline   Reply With Quote
Old 11-04-2008, 04:45 PM   #4
efsublime's Avatar
you can always top the coolant off, leave the rad cap off and turn the car on and let it idle for about 20 min. then put cap on.
efsublime is offline   Reply With Quote
Old 11-04-2008, 05:07 PM   #5
DC4 ENTHUSIAST's Avatar
Default Re: how do i flush my coolant system to get air out of the system (sleepingciv)
Quote:
Good explanation, its a good idea to let the fans kick on twice correct?
I flushed my system recently and old had one jug of coolant, not enough to completely fill the system. Anyhow I put the cap on and it hasn't given me any problems yet but I am going to add some more coolant tomorrow and burp it using the above method.
DC4 ENTHUSIAST is offline   Reply With Quote
Old 11-04-2008, 05:35 PM   #6
Default Re: how do i flush my coolant system to get air out of the system (DC4 ENTHUSIAST)
youll be waiting for ever for the fan to kick on i just did mine today
from start to finsh about 15-20 min fan vever came on lol, and yees my fan works
Ya if you car isnt idle up and down slightly you should be good just topping off the coolant.
If it starts to idle up and down the bleed it
Old 11-04-2008, 06:10 PM   #7
Cool, yeah the car is idles perfectly right now so I will just top it off. Thanks for letting me know.
Old 11-04-2008, 06:25 PM   #8
Sidewayz_240's Avatar
Also a good idea to jack the car up from the front, to make it easier for the air bubbles to get out.
Sidewayz_240 is offline   Reply With Quote
Old 11-04-2008, 06:26 PM   #9
Default Re: (Sidewayz_240)
what ??
Old 11-04-2008, 07:43 PM   #10
accordaffair's Avatar
I put a 3 foot bit of hose o the thermostat nipple and open it with the car running. I run the other end into the radiator overflow and let it run while I check other maintenance items, like timing, etc
accordaffair is offline   Reply With Quote
Old 11-04-2008, 07:50 PM   #11
Default Re: (accordaffair)
Thats a good idea man does it stream out normal at first or can ya see the bubbles?
Thats a good way to keep nasty anti freeze of the motor for sure
Old 11-04-2008, 07:52 PM   #12
Default Re: (sleepingciv)
Back in my 240 days the trick was to jack your car up from the front, to get the air bubbles out faster/easier.
Old 11-04-2008, 09:51 PM   #13
It's all bubbles at first, after a few minutes it climbs further up the hose until it starts pouring out the other end.
Old 11-04-2008, 09:53 PM   #14
Ya should have pm'd me this before geesh i had to clean my motor off lol
2001 honda odyssey coolant system mrrivee Odyssey | Ridgeline | MDX | Pilot | RDX | HR-V 0 07-16-2015 04:04 PM
Air in coolant system HELP!! jdm_obsession88 Honda Civic / Del Sol (1992 - 2000) 12 09-12-2010 02:19 PM
Coolant system question. Tunerguy1989 Honda Prelude 12 06-15-2010 01:16 PM
Best way to flush coolant system? justinwebb Honda Civic / Del Sol (1992 - 2000) 23 05-06-2009 09:24 PM
How do you bleed the air out of the cooling system?!?! Red D Dragon Tech / Misc 5 01-04-2004 02:15 AM
Tags
1990, air, bubbles, car, civic, coolant, dc4, f150, flush, honda, integra, jack, pockets, radiator, remove, system, tool
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
