How to change a starter?
Old 08-10-2005, 03:53 PM
HksHaitian's Avatar
Default How to change a starter?
Hi!
Does anyone kno how to change the starter on a 1991 Civic???
Old 08-10-2005, 03:56 PM
APEX CRX's Avatar
Default Re: How to change a starter? (HksHaitian)
disconnect battery, remove power cables off starter, unbolt the 2 long bolts on the side and pull out starter, reverse directions for install. simple as that
Old 08-10-2005, 04:01 PM
vegaskurt's Avatar
Default Re: How to change a starter? (APEX CRX)
What he said, but take the passenger tire off and the shroud behind it. It will make it a lot eaiser to get to the lower bolt on the starter.
HksHaitian's Avatar
do you kno wat size the bolt are??
Old 08-10-2005, 04:31 PM
DocSean's Avatar
17 mm probably.
Old 08-11-2005, 07:21 AM
APEX CRX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HksHaitian &raquo;</TD></TR><TR><TD CLASS="quote">do you kno wat size the bolt are??</TD></TR></TABLE>
Either 12 or 14 mm
Old 08-11-2005, 09:21 AM
Needs to be About 20% Cooler
DieMaster's Avatar
bottom bolt is a major PITA to get too.
Old 08-17-2005, 10:58 AM
oldtegskoo90's Avatar
Default Re: How to change a starter? (DieMaster)
you only need a 14mm socket, and a 12mm socket. man i wish i took off the tire, when i did my starter yesterday, damn that **** was a bitch. o well
Old 08-17-2005, 11:06 AM
D95si420's Avatar
hell if i would pull my tire and inner fender liner, its a 15 min job to do a starter on a civic. 6 inch extension and deep 14mm put the ratchet out far enough to get a good yank on it. I usually dont even remove the intake tube. Everyone else is dead on right, Power wire is 12mm and the 2 mount bolts are 14mm
AudioFunk
08-29-2014 09:48 AM
Mhollaek9
Honda CR-V & Element
03-17-2012 08:01 AM
exxybihon
08-28-2008 09:57 PM
7panget
02-12-2008 06:23 PM
slacks
10
08-27-2007 02:23 PM
Quick Reply: How to change a starter?
