Horn Relay? Do our cars even use one?
Have searched.
The problem: 89 CRX Si, no horn, fuses are fine-- horns beep with a voltage but with the horn button I get nothing
Before I go tracing the wires, I'd like to know if there is a horn relay somewhere in the fusebox. Where is it? Do our cars even have one? TIA homies
Re: Horn Relay? Do our cars even use one? (SECURITY)
I'd say they would because most EF's (well all 4 of mine did) run 2 horns, and you wouldn't run all that current through the wussy little horn button contact from the wheel to the steering column. Check for a broken horn contact behind the steering wheel but other than that I can't help ya.
look for it under the passenger's side headlight am pretty sure there's one coz i did rewire completely wiretucking stuffs under the hood.
Re: Horn Relay? Do our cars even use one? (ef92b)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ef92b »</TD></TR><TR><TD CLASS="quote">look for it under the passenger's side headlight am pretty sure there's one coz i did rewire completely wiretucking stuffs under the hood.</TD></TR></TABLE>
I think I read your thread. Those relays were for a/c correct? I will check anyways, thanks
The wire is a negaqtive trigger in the switch/button. When that wire sees "ground", the horn sounds.
I don't think the 88-91 chasis uses a relay. I have been wrong though....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SECURITY »</TD></TR><TR><TD CLASS="quote">
I think I read your thread. Those relays were for a/c correct? I will check anyways, thanks</TD></TR></TABLE>
look carefully, there's one rectangular shaped black box aside from the a/c condenser, compressor and rad fan relays
reason being i replaced my old stock OE twin horns with stebel air horn
Before I go tracing the wires, I'd like to know if there is a horn relay somewhere in the fusebox. Where is it? Do our cars even have one? TIA homies</TD></TR></TABLE>
Nope, they dont have a horn relay. Do your brake lights work, they use the same fuse.
vtec69
31
02-24-2012 06:36 AM
