Hood Latch Cable Snapped!
Old 07-26-2010, 11:07 AM
TahitianGreen's Avatar
Default Hood Latch Cable Snapped!
How can I open the hood? the cable is snapped....
Old 07-26-2010, 11:10 AM
slywfbpsi's Avatar
Default Re: Hood Latch Cable Snapped!
get another one from the dealership and replace it. Take off the front bumper and release the latch.
Old 07-26-2010, 11:12 AM
how would i take off the bumper with a closed hood
Old 07-26-2010, 11:15 AM
slywfbpsi's Avatar
unscrew the turn signals on the bumper, take out the two screws on each end of the bumper in front of the front tires. Take a 14mm socket and unbolt the bumper support from the frame. Pull the bumper off.
Old 07-26-2010, 11:22 AM
BrayzieEF9's Avatar
x2
Old 07-26-2010, 11:34 AM
$cat /dev/urandom
sanimalp's Avatar
where did it break? The cable runs through the driver side wheel well. If you take the plastic splash guard out of the wheel well, you can see the cable. if the break is upstream, then you can cut the casing off the wire and grab the wire with some vice grips. then replace it.
additionally, between the front crossmember and the bumper cover there is another point where you can usually see the cable, so you might be able to get some vice grips in through there, but sometimes the ac condenser is in the way.
bumper removal would be more work, so i would try the wheel well option first if you have some idea where the break is, then going in through the front bumper, and then taking the bumper off as a last resort.
Old 07-26-2010, 11:42 AM
slywfbpsi's Avatar
There's many ways he can take it off. Heck he can undue the two 10 or 12 mm bolts under the bumper attached to the splash guard and pull the bumper back far enough and take a long flathead screwdriver and unscrew the locking pin if he wanted to. I gave him the option that he is gonna have to do anyway if he is going to replace the cable. You can run the new cable through any hole in the firewall that you want to, but you will still need to take off the front bumper to attach the cable to the locking mechanism.
Old 07-26-2010, 11:44 AM
BrayzieEF9's Avatar
either way both things have to come off,the wheel well cover and front bumper to replace the cable.
Old 07-26-2010, 11:57 AM
BiG ChOr!Zo's Avatar
bumper doesn't need to come off to replace the cable...if cable is snapped cut it and expose the wire cable inside the black casing and pull on wire with some pliers and the hood will open from the driverside wheel well.
as for putting in the new cable just remove the t-bar and wiggle the new cable under the headlights through the wheel well into the cabin.
Old 07-26-2010, 11:58 AM
CRXREFIC's Avatar
this is a little trick in learn on my car..
if u go behind the middle bar of the radiator support (if u can get behind the front bumper that is) their is a little switch sorta connected to the latch mechanism..
and its on the left side behind the bar it will take time and u will feel it... once u find it push the hood down and push onto the lever it will unlock the hood...
Old 07-26-2010, 12:05 PM
BrayzieEF9's Avatar
I meant replacing it properly, using the clips still.If you remove the T-bar your gonna have to get on the ground to get the bottom bolt and if you still have the splash guards under there.It's just gonna take the same amount of time,taking the bumper off.So why half *** it,when you can do it properly in the same amount of time?
Old 07-26-2010, 12:07 PM
BrayzieEF9's Avatar
lol its not a trick? it's common sense,not trying to be a douche or anything.
Old 07-26-2010, 12:11 PM
CRXREFIC's Avatar
ya douche lol it was a lil trick for me because i had to figure it out
Old 07-26-2010, 12:15 PM
BrayzieEF9's Avatar
Old 07-26-2010, 12:17 PM
so you take off the entire bumber just to save a clip not as half *** as you make it seem and one 10mm bolt on the bottom of the t-bar is a lot faster than taking off a entire front bumper...btw the splash guard doesn't have anything to do with removing the t-bar
Old 07-26-2010, 12:21 PM
Canadian_EF's Avatar
i could just fit a ratchet in the vent hole in the front of the bumper, and unbolt that one bolt. it's how i replaced my t-bar once upon a time... saved me taking off the bumper...
Old 07-26-2010, 12:29 PM
BrayzieEF9's Avatar
why do you guys act like taking off a bumper is the hardest thing ever? it only takes 5 mins.you still gotta take off the splash guards in the wheel well if he has any ,and why wrestle with a cable to open the hood?
Old 07-26-2010, 12:34 PM
who ever said it was hard...we said that it was pointless and unnecessary...besides that who uses splash guards now a days and my cable opens with ease...!!!
Old 07-26-2010, 12:39 PM
BrayzieEF9's Avatar
I use Splash Guards
Old 07-26-2010, 12:44 PM
I use Splash Guards
i dont...it doesn't rain enough in california to justify their use...!!!
Old 07-26-2010, 12:46 PM
BrayzieEF9's Avatar
well it rains here all the time in Portland,OR even during the summer
Old 07-26-2010, 01:01 PM
CRXREFIC's Avatar
splash guard is on mine too
the only gay thing about removing the bumper is that the screws are half of the time real hard to unscrew with a right philip and it will even strip easily....
Old 07-26-2010, 01:03 PM
BrayzieEF9's Avatar
I've never had a problem with said screws
Old 07-26-2010, 01:42 PM
CRXREFIC's Avatar
i have dam lol throughout all my crxs
and even my friend crx's
Old 07-26-2010, 03:01 PM
i got it
just removed the bumper
Quick Reply: Hood Latch Cable Snapped!
