Honda D series engine
Old 12-10-2009, 12:12 PM
  #26
New User
hondauberalles's Avatar
Default Re: Honda D series engine
hey mate its theo from greece.yr info is great!i wanna ask ya sth.
i ve got a d15z6 civic which s changed engine.it used to be 1.4lt(90hp) so now its 1.5lt(115hp).the point is that i ve got some problems mostly in 4th n 5th gear.like small cuts of the fuel.i ve been searchin for it since i bought it n the only thing i know is that it comes from electricals..sensors maybe..i m just wanderin that the car had a stock immobilizer as a 1.4tl.could the ex owner change the ecu from the 1.4 to a 1.5 ecu or he just left the 1.4 ecu n only changed the engine?????how can i check my ecu type cuz here nobody wd tell me!!
hondauberalles is offline
Old 12-10-2009, 02:26 PM
  #27
89s1's Avatar
Originally Posted by sw96
Nice. Now to identify which ZC is in my EF. All I can remember right off is that the block is stamped ZC.
count the cams
Originally Posted by D16SiHatch
really? there are that many people who couldn't find this info on their own?
Amazing isn't it? Not surprising, but amazing.
89s1 is offline
Old 12-10-2009, 11:02 PM
  #28
fatCRXguy's Avatar
me== d series
fatCRXguy is offline
Old 10-24-2010, 01:29 AM
  #29
johnnychavo's Avatar
help! im putting a d15b7 into my 1991 si. can I just use the d15b7 intake manifold using the 1991 si mpfi harness and an obd0 2 obd1 jumper to use the p28 ecu and obd1 dizzy and o2 sensor? any help please pm me or txt/call 9165087417 thanks
johnnychavo is offline
Old 10-24-2010, 10:50 AM
  #30
efjones9's Avatar
no u will have to do a mpfi swap.
check this out
http://www.google.com/webhp?rls=ig#s...9faa430ac3503f
efjones9 is offline
Old 10-24-2010, 11:56 AM
  #31
check this out
I have a mpfi harness from an ef si cant i just use that? its already mpfi. wat other conversion would i have to so? and I bought this
http://cgi.ebay.com/ebaymotors/1988-...D1-CONVERSION-
JUMPER-HARNESS-/120634462943
shouldnt that be all I need?the jumper makes it possible to keep the obd1 ecu and dizzy and the 4 wire 02 sensor
Old 10-24-2010, 12:26 PM
  #32
Grey_Matter's Avatar
so in essence i should be able to use the stock intake/exhaust/fuel management on a newer block say from a d15b2 to a d15b7
Grey_Matter is offline
Old 10-24-2010, 12:38 PM
  #33
I think so. all d series mpfi manifolds are basically the same.I have an ecu jumper harness and a distributor conversion plug. that with the mpfi harness should be good enough...right?
Old 10-24-2010, 05:07 PM
  #34
Nooch's Avatar
Haha, exactly what I was thinking. As I read some first information I was thinking,
"Hmm, who the **** is NOT going to know this **** beforehand?"
Then I look at the next few posts, and think,
"Well, there sure are people who don't search for anything worth a ****."
Nooch is offline
Old 10-24-2010, 05:58 PM
  #35
thebluecrx's Avatar
great great info thanks. helped alot
thebluecrx is offline
Old 10-24-2010, 07:19 PM
  #36
Tyson's Avatar
this is a copy and paste from wikipedia and full of BAD INFO!
UNRELIABLE SOURCE.
Tyson is offline
Old 10-24-2010, 07:25 PM
  #37
looked but found no info pertaining to me.thanks to those that answered
Old 10-24-2010, 08:07 PM
  #38
jdm ef8 89's Avatar
jdm ef8 89 is offline
Old 10-24-2010, 08:08 PM
  #39
jdm ef8 89's Avatar
lol the d17a5 has 0 hp?
typo or slowest engine ever
Old 10-30-2010, 12:05 AM
  #40
jaycorolla's Avatar
my question is can up put a d16a6 cam into a d15b1 head that has the mpfi intake manifold from an si and also the computer conversion already done???
jaycorolla is offline
Old 10-30-2010, 03:57 PM
  #41
EFB055
~sp33~'s Avatar
Yeah you can.
~sp33~ is offline
Old 11-05-2010, 10:57 AM
  #42
jimmy janeiro's Avatar
Icon2 Re: Honda D series engine
what would be the easiest and least expensive swap from my D15B7 with a broken snout on the crank to an engine with a little more power? Thanks
jimmy janeiro is offline
Old 11-05-2010, 03:02 PM
  #43
psjones13's Avatar
In order from easiest swap to most power. D16a6, d16z6, d16y8. They are all however "easy swaps" and the power bands are all similar. But the last 2 have vtec.
psjones13 is offline
Old 11-06-2010, 11:47 AM
  #44
Thanks for the information.
Old 11-10-2010, 01:13 PM
  #45
Tmks's Avatar
Thank you so much this has helped me a lot as a young girl trying to figure all this out on her own.
Tmks is offline
Old 11-10-2010, 01:27 PM
  #46
Tmks's Avatar
how much am I looking to spend on a head for a D17A2 series engine?
Tmks is offline
Old 11-10-2010, 09:02 PM
  #47
EFB055
~sp33~'s Avatar
$53.09
~sp33~ is offline
Old 02-06-2011, 10:19 PM
  #48
marcelino's Avatar
sorry to come into this thread and start asking questions but im lost on wuts wrong with the car. my brother and i got ahold of this 1990 civic ef body with the d15 from crx from the same yr. we have been having problems running. it will iddle ok but once we take off it will only do about 50 tops it ill start to slow down even if im pressing the gas peddal all the way i thought it could be the spark plugs and the cables so we changed them but didnt change also changed the gas filter and cleaned out the injectors cuz it wuz giving trouble code 16. the check engine light turned off but its still flashing. it will have a single flash(cant tell if its long or short) flashes 12 times quickly but i dont know if its supposed to flash like that or its the egr sensor. what im now wondering is if the d15 engines have egr sensors and if so where .......if any one can help me or redirect me to another thread that can assist me i would realy REALY appreciate it thanks in advance guys
marcelino is offline
Old 02-07-2011, 08:45 AM
  #49
theft24's Avatar
google must have started charging for its searches
theft24 is offline
Old 04-20-2011, 04:42 PM
  #50
HondaGuy19890's Avatar
Originally Posted by DCFerris
Thank God maybe we will see a decrease in whats the diff between this d and that d post your a good good person guysensei
okay one down fall to all that is that even know its very helpful to most but it states nothing about transmission selections that bolt up to any of the engines
HondaGuy19890 is offline
Quick Reply: Honda D series engine
