help plz 99 honda prelude 5 lug suspension fit onto 1990 crx??
Re: help plz 99 honda prelude 5 lug suspension fit onto 1990 crx??
This is not a direct bolt up in the front rear idk since i do not know the suspension geometry of a prelude but here is a link to the itr
http://www.ff-squad.com/technet/how-to/5lug.ef-da/
i dont know nothing about the prelude knuckles or hubs you might want to research that
well acording to this
the prelude hubs are not the same as the itr you might want to read this thread
https://honda-tech.com/forums/suspension-brakes-54/5-lug-conversion-using-4-lug-spindles-front-rear-1978033/
AS FOR THE FRONTS, YOU CAN USE CR-V KNUCKLES. THEY ARE THE SAME PART FOR JDM TYPE R DC2 KNUCKLES. OR YOU CAN USE EX OR INTEGRA KNUCKLES BUT YOU WILL NEED TO GET:
USDM ITR HUBS (32MM HUBS) AND ITR, 4-LUG INTEGRA OR CIVIC BEARINGS
OR CR-V, PRELUDE HUBS (36MM HUBS) AND CR-V OR PRELUDE BEARINGS(GREAT FOR JDM ITR SWAPS)
23T CALIPER BRACKETS FOUND IN ITR, PRELUDES H22 92-01, ACCORD WAGONS, CR-V, ACURA LEGEND.
CALIPERS FROM ITR, CR-V, PRELUDE H22 92-01 (THEY ARE ALL THE SMAE CALIPER) OR ACURA LEGEND (DUAL PISTON CALIPERS)
ROTORS FROM ITR, CR-V, PRELUDE H22 97-01.
. o 69 o .
07-18-2005 10:51 AM
