D16 build question
D16 build question
Wondering what would be the best way to build my stock d16a6. I was thinking low compression pistons with a turbo set up, but wasn't too sure if that would be the right thing to do. Any advice?
Re: D16 build question
comp test, leak down. If it isn't half in the grave save up for a turbo kit. Wen you have everything. Change your oil pump,water pump,timing belt, and do a tune up with ngk(1 strp colder) spark plugs, arp headstuds and put 150whp down. Just a starting point. Going for 80whp to 250whp is stupid. but the single will take that abuse
