help with fuel pump 91 civic - Honda-Tech
Old 06-16-2009, 10:56 PM   #1
94civicdeleon's Avatar
Default help with fuel pump 91 civic
I have a 91 civic hatch and I need to replace the fuel pump. how do i do this because i cant find any fsm anywhere for this. I am putting in a GSR fuel pump cuz i am running a b16a so if you could help that would help thanks a lot.
94civicdeleon is offline   Reply With Quote
Old 06-16-2009, 11:41 PM   #2
D16SiHatch's Avatar
Default Re: help with fuel pump 91 civic
you don't need to put in a gsr pump to run a b16a, we already covered this in the other thread you made about this..
but whatever i guess. its also not that difficult, but here's the steps..
fuel tank removal:
1. Block front wheels, then jack up the rear of the car and support with jackstands.
2. Remove the drain bolt and drain the fuel into an approved container.
2. Remove the rear seat and disconnect the 4P connector.
4. Remove the two-way valve cover and the fuel hose protector.
5. Disconnect all hoses. CAUTION: When disconnecting the hoses, slide the clamps back out of the way, then twist the hoses as you pull them back to avoid damaging them.
6. Place a jack, or other support device, under the tank.
7. Remove the strap nuts and let the straps fall free.
8. Remove the fuel tank. NOTE: The tank may stick to the undercoat applied to its mount. To remove, CAREFULLY pry it off the mount.
10. To install, replace the washer on the drain bolt, then reverse the above procedure.
fuel pump removal
D16SiHatch is offline   Reply With Quote
Old 06-17-2009, 10:01 AM   #3
yeah it's because i lost the other thread sorry
91 civic hatch fuel pump.... Need help ASAP osbunjosh Honda CRX / EF Civic (1988 - 1991) 8 03-19-2013 10:22 PM
91 civic not getting fuel to the filter or rail? GRIMRemembeR Honda CRX / EF Civic (1988 - 1991) 2 01-29-2013 01:14 AM
91 civic hatch fuel pump location? ProjectGreenLS Honda CRX / EF Civic (1988 - 1991) 5 09-01-2003 08:41 PM
fuel system compatibility Audipwr1 Honda CRX / EF Civic (1988 - 1991) 1 09-09-2002 01:36 PM
Installing supra fuel pump, pls help deacs Forced Induction 0 09-09-2002 05:46 AM
Tags
91, change, civic, dx, ef, fuel, gas, hatch, honda, pump, pump91, removal, remove, replace, tank
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
