help choose the rigt oil for a rebuilt d16a6
Old 07-22-2011, 01:27 PM
rudyndrew's Avatar
Default help choose the rigt oil for a rebuilt d16a6
So I did some searching & found out that conventional oil breaks down @ high temps & synthetic doesn't then also that some synthetics don't protect your engine & some add hp. Well I for 1 don't care if oil adds pwr or not, I just want a full synthetic that protects. I always use 10w30 castrol gtx. Any advice to what will protect my d16 & keep it healthy? Its also summer time her in socal its like 91degrees right now & want my ride to perform good. I do drive it hard daily.
Old 07-22-2011, 03:03 PM
1990edsedan's Avatar
Default Re: help choose the rigt oil for a rebuilt d16a6
Run 15w40 Mobil 1 synthetic.
Old 07-22-2011, 03:28 PM
rudyndrew's Avatar
Whats good about this oil y the 15w40? Just asking.
Old 07-22-2011, 03:33 PM
rudyndrew's Avatar
The 15 is for temperature/degrees right? And the 40 I'm guessing is thickness? I forgot how to understand it.
Old 07-22-2011, 03:49 PM
Keyboard Humorist
4drEF's Avatar
All the info on oil you will ever need.
http://www.jeepfan.com/tech/motoroil-faq.htm
Get a quality brand and go with manufactures spec for the oil.
5w30 or 10w30 (10w30 for warmer climates)
The viscosity of multi-weight motor oil is specified using two numbers. The first number is the viscosity when the oil is cold. This is followed by the letter W (which stands for winter, not weight), which is followed by the number that indicates the viscosity when the oil is at operating temperature. The higher the number the thicker the oil.
On a rebuilt motor there is no reason to go with the thicker 40 weight. Manufacturer recommends 30 weight. Putting 40 in would create unnecessary drag inside the engine. people sometimes use 40 to 'band-aid' problems. No need on a rebuild that you have.
If you stick with a quality brand, you can switch between synthetic and conventional whenever you want... it won't matter.
Old synthetics had a different chemical makeup and would seal differently so they would leak in old engines.
Today that has improved greatly and you can switch between the two all you want.
That's where there are so many semi-synthetics on the market today.
Old 07-22-2011, 04:28 PM
JacksonD's Avatar
The big factor in choosing a weight of oil Is the condition of the crankshaft. Did you get it checked or micro polished during the rebuild? If it is worn down badly you could choose thicker oil to extend life and reduce potential oil burning.
Old 07-22-2011, 04:56 PM
Crazy Honda Guy
Deetz's Avatar
DO NOT, use a synthetic oil on a fresh engine, it has to be well broken in 1st
FitsMe
Honda Fit
04-16-2012 05:05 AM
P@@RB@Y
11-05-2005 07:19 AM
vtec.dc2
03-06-2004 02:42 AM
V-Thang
Acura TL, RL & ZDX
01-09-2004 11:04 AM
blkbeast
05-28-2003 10:48 PM
Quick Reply: help choose the rigt oil for a rebuilt d16a6
