HElp!! Car smokes White n smells like Gas - Honda-Tech
Old 03-14-2006, 11:12 PM   #1
FastHatch90's Avatar
Default HElp!! Car smokes White n smells like Gas
Okay so i baught a 90 Hatch si with the DOHC zc motor swap for $1000 like 1 1/2 months ago... i start it up n it smokes white n smells like gas.. can anyone help with this???
FastHatch90 is offline   Reply With Quote
Old 03-14-2006, 11:50 PM   #2
payneth's Avatar
Default Re: HElp!! Car smokes White n smells like Gas (FastHatch90)
white smoke out of the exhuast? all the time or on acceleration? need more info. But it sounds like your headgasket is blown. The gas smell... Well.. You could check and make sure you're not leaking gas from the injectors, or the fuel filter. A buddy of mines hatch was smelling like gas and i looked at it and one of the bolts on the fuel filter was loose causing the gas fumes to escape and the heater core sucked the air into the cabin and WALLA!! you have gas smell.. So check and make sure there are no leaks on your filter and makesure the injectors are nice and dry. but there can be more causes.
payneth is offline   Reply With Quote
Old 03-15-2006, 01:19 AM   #3
Shirk's Avatar
Default Re: HElp!! Car smokes White n smells like Gas (payneth)
Quote:
Same thing happened to me. Gas fumes at every start up.
For the white smoke, do a compresion test and post the results.
Shirk is offline   Reply With Quote
Old 03-15-2006, 01:48 AM   #4
payneth's Avatar
Default Re: HElp!! Car smokes White n smells like Gas (Shirk)
yeah a compression test would really tell ya whats going on with your car
Old 03-15-2006, 02:57 AM   #5
crxnj's Avatar
The smoke may just be because its really cold out,,I see you're in MD..For the exhaust fumes,,its pretty normal to smell fumes seeing how thats what motors burn,,But if its really strong and bad check the exhaust manifold..Maybe leaking up there or something..ALso do you know if the car has a catylist converter on it? I mean does it even have a full exhaust,? Besides that, check the fuel filter,,And also check the back to see if its leaking gas from the fuel line in the rear,,Mine was completely rotted out ,,Thanks to the northeast weather..
crxnj is offline   Reply With Quote
Old 03-15-2006, 09:07 AM   #6
og_hatch_90's Avatar
your car is probably just running rich... reset the ecu by unplugging the negative battery terminal for a minimum of 30 seconds..overnight if possible...if that doesnt work..try manualy adjusting the fuel mixture. what are you idling at btw?
og_hatch_90 is offline   Reply With Quote
Old 03-15-2006, 11:46 AM   #7
The exhaust fumes is wut smells like gas...n yes it seems to smike all the time although it has been cold out here...N i dont know how to do a compression test cuase i know little about motors. Also there seems to b a liquid shooting out of the exhaust while its running???? any more sugestions?
Old 03-15-2006, 11:59 AM   #8
crxnj's Avatar
Quote:
If there is water coming out of the exhaust that means the catylist converter is working,,Its 100% normal..
91 civic hatch dx white smoke tailpipe gas smell in coolent res tooltechleo414 Honda CRX / EF Civic (1988 - 1991) 2 05-31-2015 02:06 PM
'90 cx white smoke fuel smell in exhaust, not HG, help? silverstar4life Honda CRX / EF Civic (1988 - 1991) 11 02-21-2012 05:56 PM
Car smells like gas when i press pedal all the way down. panchlow Honda Civic / Del Sol (1992 - 2000) 1 09-11-2010 12:55 PM
d16 and i have a gas smell in my oil???? Redprelude98 Honda Civic / Del Sol (1992 - 2000) 18 04-11-2009 10:49 AM
whats up with all the smoke? Honda97 Acura Integra 16 03-10-2005 06:06 PM
Tags
2000, car, civic, exhaust, fumes, gas, honda, integra, normal, smell, smells, smoke, smokes, started, white
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
