HELP
Old 01-10-2002, 11:58 AM
87posCRX's Avatar
Default HELP
ive got to change my oil.. i have a floor jack, jack stands, and all the tools.. how do i get the jack stands under the lift points while the jack is up? i dont want to support the car anywhere else than the lift supports.. i dont want to screw up the body panels
AHH
Old 01-10-2002, 12:01 PM
markedOO1's Avatar
Default Re: HELP (87posCRX)
..find the central jacking point in the middle of the car...somewhere behind the front bumper...jack it here and put the stands under the other lift points....
Old 01-10-2002, 12:15 PM
keithv's Avatar
This link should help.
http://integra.vtec.net/geeser/jacking.html
Its an Integra but the Civic is the same.
Old 01-10-2002, 12:19 PM
New User
SiR Kid's Avatar
Default Re: HELP (marked001)
If you look under the front of the CRX/4th gen civics and 2nd gen integ's there's a jacking point in the MIDDLE of the front crossmember.
It just looks like a reenforcement in the dead center of the car...
Jack it up high and put the stands under the frame rails that run between the doors and the front wheel wells. Look for the metal that is pinched together into a rail under the car... should only be 4-6 inches un from the side of the car. Make sure both sides are tight against the rails, and lower the jack to put the weight on the stands. Voila. Change your oil.
Old 01-10-2002, 12:34 PM
87posCRX's Avatar
thanks guys
helped alot
a lil diff cause its a 1st gen rex, but i figured it out
the oil is drainin now
Old 01-10-2002, 05:12 PM
rpr
rpr's Avatar
You're done, but an easier place for the jack stands is on either side of the jack, under the front cross member. I had to do this so I didn't have two jack stands poking through my floor...
teambroken
02-10-2007 10:09 PM
justint
08-09-2006 07:32 AM
l3loodred
09-16-2003 05:10 PM
^jefs0ng
04-01-2002 09:34 PM
Mr.FBR
11-30-2001 07:10 AM
Quick Reply: HELP
