heating problem please help
Old 02-15-2009, 03:45 PM
89CivicHb1's Avatar
Default heating problem please help
i have a 89 civic hatch with a 1990 ls swapped in it im having a heating problem new thermostat new water pump new hose's new radiator and my car keeps overheating. when the car is just sitting there the temp is pefect. sometimes my heat will go away but then other times its very hot and when i go to drive it it starts overheating and when i stop driving it will go back to normal temp when i turn the heat on sometiems the temp gauge goes up and it will over heat i block tested my car and it is not showing any signs of hydrocarbons so i dont think it is a blown head gasket or anything cus i have no signs of coolant in my oil either so if anyone can help me that would be awsome
Old 02-15-2009, 03:54 PM
DO IT ON ALL FOURS
OneBadTurboCRV's Avatar
Default Re: heating problem please help
Did you bleed the air out of the engine?
Old 02-15-2009, 04:36 PM
89CivicHb1's Avatar
yeah i bleed the system today and its still shitty mabe i need to bleed it more but idk is there anything else i can do?
Old 02-15-2009, 04:53 PM
DO IT ON ALL FOURS
The only thing I can pull from what you typed in your first post is that when you turn the heat on it starts to overheat. Well this tells me that there is still air in the coolant system. I would take the cap off the radiator and start squeezing the upper and lower hoses and keep adding coolant as needed. If it is done properly then you shouldn't even have to bleed the coolant system.
Old 02-15-2009, 05:15 PM
89CivicHb1's Avatar
ok im going to do that tomorrow thanks
Old 02-17-2009, 07:37 AM
89CivicHb1's Avatar
Fixed the problem it was a massive air bubble in the system i bought the universal radiator funnel and just let the car run with coolant in the funnel and it did the rest i think this is somthing everyone should get because it just is amazing this is what the kit comes with it is only like 35-40 dollors too
Last edited by 89CivicHb1; 02-17-2009 at 07:38 AM. Reason: wanted to tell how much the kit was
DTHADDR
11
02-05-2013 12:28 AM
tech410
15
09-22-2010 05:22 AM
xxxmikenicexxx
07-07-2006 12:25 PM
only1gcue
04-15-2006 01:42 PM
Gabe_
12
06-13-2003 02:47 AM
Quick Reply: heating problem please help
