heat Wont get HOT!
heat Wont get HOT!
YES i have searched and read everything you can possible read. but for some reason my heat will not get Hot. the temperature gauge will read normal and i can even feel the lines on the back of the heater core from inside the car and they are hot.
but i can turn on the blower to high (4) and it will blow almost hot air for about 30 seconds, then go Luke warm. then i turn it off for 30 seconds and back on and just repeat the same thing over and over....
i have read other threads, on which way all the valves should be. but could someone please help me go over this again!
Re: heat Wont get HOT!
but the whole time, like i said in my first post. i can feel the lines coming into the heatercore inside the car and they STAY HOT
Possibly a blocked heater core causing poor flow of hot coolant; not enough hot water flowing through to replace the heat being removed by the fan.
2 1/2 years old i think it came from Auto Zone, cause Honda was out of them the day i needed it.
does anyone have a diagram of the coolant hoses going into the heater core from the engine?
Only 2 hoses go from the back of the engine through the firewall,one goes through a valve first.They are located in the middle of the car by the throttlebody.
Put a cooling system flush through the car first and see if that helps and when you are flushing everything out take both of the heater hoses offand use a garden hose and put it in both of the heater core pipes to flush it out well.
_______
before i put the new heater core in i used my pressure washer to clean it, and the water flow is GREAT!
One from valva goes to the water outlet spout on the head under the dizzy area and the other one goes to the spout on the thermostat housing.
i just fixed mine and i knew what it was from minute one. car idling it gets hot...under load thermostat wont stay put and it flushes all coolant back through system. its the thermostat. Fix the hose and new thermo. I promise....if it doesnt ill pay for your parts
dantamparacer
08-05-2010 06:51 PM
